Question about Ovens
I have a side by side model GS5SHAXNT00. I heard a small pop and the bulb went out. When I replaced the bulb it did not work and the temperature control display went dark. both bulbs work well
5 Suggested Answers
  • 159 Answers
SOURCE: Replace Bulb on Oven Display
I dont thinkits as easy as just replaceig a bulb. you have a electronic display on there. what it sounds like its the display thats bad. I dont know if it is a seperate part or attached to the control bord like most others. Most times it is attached. and that meand the control bord will have to be replaced. I dont now how old the oven is but some manufacturers will have a 5 year parts warenty on the electronics. may be worth finding that out first. Replacing it is the only way to resolve your problem.
Posted on Aug 06, 2007
  • 3463 Answers
SOURCE: neff 1861 oven fan stopped working
Fitting new bulb would not cause fan to stop working.
If it is getting hot, then there is something wrong with fan, try spinning fan by hand, it should be free, and continue to spin under it's own momentum.
Hope this helps.
Plz rate my solution.
Posted on Dec 29, 2008
  • 572 Answers
SOURCE: oven seems to work but the display panel dark.
Posted on Feb 11, 2010
  • 9098 Answers
SOURCE: 1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts -
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
Posted on Dec 19, 2015
Why will my kenmore oven only heat to 212 degrees after 2 houres?
Why is the oven temperature incorrect?
The oven temperature control is usually controlled by a thermostat that uses a capillary and liquid filled bulb. When the bulb's liquid gets heated up, it expands and puts pressure on a diaphragm which opens and closes a switch that controls the gas to the burner. Just set the dial to what you need the temperature to be. Over time, it is possible for your thermostat to lose its calibration. Sometimes, the thermostat sensing bulb comes loose from the holder. If it is out of place, the thermostat may be getting faulty readings. If this is the problem, re-aligning the bulb properly will take care of this problem.
Digital display models use a sensor to control temperature. If this is faulty, replace it. Other ovens use a mechanical system to control the temperature.
On many models, you can adjust your oven thermostat using a small screwdriver. The adjusting screw is located on the thermostat valve stem. Remove the knob and you'll see the screw underneath it. You want to turn the oven on and run it through at least two cycles while watching a calibrating thermometer in the oven for high and low temperatures. Adjust the screw as necessary to fine tune the temperature.
Some models don't have an adjustable thermostat, and you will have to replace the thermostat if you want to resolve the problem.
May 28, 2014 | Kenmore Ovens
Ovens Logo
35 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
