Question about Optics
I lost battery pack on my 12 x 32 Fujinon were can I replace or repair
Dust removal inside fujinon techno-stabi binocular
The case has to be opened for this, and a can of compressed air used. There is the risk that the binocs can be knocked out of collimation, so you'd best ask a repair tech for a quote.
Sep 19, 2016 | Fujinon Techno-Stabi Binocular
How to disarm Fujinon SRD-92B Zoom Rate Demand
Remove end plate. Remove rate control knob and pot. Loosen up three set screws on housing, center zoom control, and slide entire assembly out the end of the housing. Where will you find a replacement spring?
Feb 28, 2013 | Fujinon Inc SRD-92B Zoom Rate Demand with...
Techno stabil 14x40 . yellow light comes on. Green light wont follow. Pwr button will not turn off pwr . of course if gr does not come on no IS
Hi.
The binocular is behavior is the same as when the electronic control module is defective. First try resetting the electronics by pulling out and putting back the AA batteries. The power reset in some occasion may unlock a jammed control module. If you have an external power adapter also test the binocular using the power adapter.
If that does not help the control board must be replaced. Disassembling of optical units is quite delicate and require experience. In that case I suggest contacting Fuji to get support. You can also get a quote on repair from a third party service. Here the online form: Repair Form.
Here some contacts. You will find your local Fujinon contact on the user manual provided with the binocular:
FUJINON INC.
10 HIGH POINT DRIVE, WAYNE, NJ 07470 U.S.A.
TEL:973-633-5600 FAX: 973-694-8299
FUJINON (EUROPE) GmbH
2 HALSKESTRASSE 4, 47877 WILLIcH, GERMANY
TEL: 2159-528545 FAX: 21 59-51 315
See also : Technical Service
Regards.
Ginko
Aug 28, 2011 | Fujinon Techno-Stabi Binocular
I purchased a Fujinon 3.5-10X50 rifle scope a few years ago and mounted it on a Remington 7 MM Mag. I am unable to pull a group less than 12 inches at 200 yards and have not been able too since installing...
It is most likely the mounts not the scope. I would just install it on the new gun and check it there. Most times a scope that wanders is the mounts. One thing with big scope is they need to be tight or the recoil will move it in the mounts. Next due to being tight when the gun heats up it can and will tweak the scope in the mounts enough to move your center. Try it in your other gun, try 3 shot groups and let the gun cool. Recheck your center. If it is good with a cold gun all is well. If it moves from one day to the next it is the mounts. If you count the clicks to recenter, come back the next day and move it the same clicks, it is the mounts. If it is all over the place, day after day it is the scope.
Jan 21, 2011 | Fuji non 4-12x42mm Rifle Scope
7x50 Marine binoclars, Fujinon w/compass. How do you swing the compass to get it to read more acutely? The compass rose, while viewing through the lense, is slightly off kilter (not centered in the view)....
I've been thinking about this for awhile, and it seems to me you're experiencing a factory defect. I don't have one of these devices, or I'd know what "normal" was for compass, but if you can't easily have the display centered, something is out of kilter. Was it always like this, or did it just start occurring recenty? Your best venue would be to contact Fujinon support and see if they will replace or fix the problem. Here is their site:
http://www.fujinon.com/NewsAndEvents/PressReleases/pr.aspx?id=84
Good luck, and hope this helps.
Dec 31, 2010 | Fuji Optics
Fujinon Technostabi 14x40--battery compartment,clip that holds battery in place broke off,need new battery compartment
I had this problem a couple of years ago. I bought a new battery compartment from Fujinon's US repair center: http://www.bakermarineusa.com. It was about $38. Unfortunately I now have the same problem with the new battery compartment. I'd like to find a source of the metal spring clips.
Nov 28, 2009 | Fujinon Techno-Stabi Jr. (12x32) Binocular
Fujinon-Mariner WPC-XL Lens Cap replacement
You can order a replacement set at: http://www.bakermarineusa.com/index.php?id=17&cat=38&prod=137
Dec 02, 2008 | Fujinon Mariner WPC-XL Binocular
Optics Logo
29 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
