On my Echo Dot, all light on top are red. Cannot get them turned off and Alexa will not respond. Have unplugged and and plugged back in. Always comes back to all red lights Help!!!
texasdan
  • 60 Answers
SOURCE: Toshiba TN55X81 Wont turn on but I hear clicking
Pull the three connectors to the yokes on the convergence board. If the set powers up, it's a good chance the STK392-110's need to be replaced. I fixed one today, and it has been running for 6 hours now.
-Dan
Posted on Sep 28, 2008
  • 2334 Answers
SOURCE: AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Posted on Nov 27, 2008
getbharti
  • 33 Answers
SOURCE: blinking red light
Red Light blinks when the ink cartridge is bad..
to check which one is bad..
take out all cartridges from the printer and clean the copper contact and the inner area of the cartridge slot with a lint-free cloth...
power off the printer and unplug the power cable from the printer..
press & hold the power button on the printer for 60 seconds..
connect the power cable and power on the printer..
insert any ONE cartridge and close the door..
similarly insert other cartridges one by one and close the door and check if the light blinks..
if it blinks ..it means the respective cartridge is bad and replace it..
if u have replaced all the cartridge..it might be possible that the cartridge sensor inside the printer have gone bad..
if this is the case so ..u might service the printer..
but I will suggest to go for a new printer as 7660 is quite an lod printer which hp launched in 2004 or 2005..
even if u have juz bought it ..it will be refurbished one..
Posted on Nov 28, 2008
  • 41 Answers
SOURCE: wont turn on red light flashes
The error code of 2x red flashes tells me you need a Y DRIVE ASSY and the part number is AWZ6649. It should be replaced by a Technician thou.
Hope this hleps
Posted on Mar 30, 2009
SOURCE: Thomson DVB Top Up Box
www.digitalspy.com/forums/showthread.php?p=31773855
IF you're lucky, this may help....?
This restes the bios but removes all recordings from the hard drive.
Good luck!!
Posted on May 03, 2009
I've just set up an echo dot in another room but it's taken control of my sitting room lihgts from my echo plus which now say sorry, i didn't see sitting room lights.
try renaming the room of your lights and make sure both echos are synced up to one account otherwise it may make both of them confused on how to control the lighting in your home
Dec 16, 2017 | Echo Computers & Internet
Need echo dot app with setup instructions
hi Gary.
  1. Turn on Echo Dot. Place your Echo Dot in a central location (at least eight inches from any walls and windows). ...
  2. Connect Echo Dot to a Wi-Fi network. In the Alexa app, follow the instructions to connect Echo Dot to a Wi-Fi network. ...
  3. Talk to Alexa. ...
  4. Optional: Connect Echo Dot to an External Speaker.
Amazon.com Help: Set Up Your Echo Dot
https://www.amazon.com/gp/help/customer/display.html?nodeId=201994280
if this does not help you out go to this link and read up some more.
echo dot app with setup instructions Google Search
Nov 20, 2017 | Echo Computers & Internet
Setting up echo dot
hi roger.
see if this helps you out.
or if you need more help go to this link.
Setting up echo dot Google Search
Nov 16, 2017 | Echo Computers & Internet
Need to connect echodot. How do I do
I this video you will show how we can connect our Echo dot device to Alexa. It is the complete way to use of Echo dot to Alexa, use of Wi-Fi connection and Alexa skills.
Oct 17, 2017 | Computers & Internet
My echo won't turn on, I've tried the fix on my app but the orange light doesn't come on
to restart your Echo device, unplug the power adapter from the back of the device or from the wall outlet. Then, plug the power adapter back in. To reset your Echo Dot that has volume buttons:
  1. Press and hold the Microphone off and Volume down buttons at the same time until the light ring turns orange (about 20 seconds). Then light ring turns blue.
  2. Wait for the light ring to turn off and on again. The light ring then turns orange again, and your Echo Dot enters setup mode.
  3. Open the Alexa app to connect your device to a Wi-Fi network and register it to your Amazon account.
You did not state if it is a dot or not if it is not a dot, there is a reset button that you can press in with a paper clip.
I hope this helps.
Aug 18, 2017 | Orange Computers & Internet
Trying to set up Alexa Dot and the instructions found all use a smart phone. don't have smart phone only flip. Can I set up using my Kendal Fire or my lap top & how to setup using one of my devices?
If your Kindle Fire uses Fire OS 3.0 or higher, it should work, provided the Kindle has Wi-Fi capability.
if your laptop has functional Wi-Fi, you can also use your favorite web browser (Safari, Chrome, Firefox, Microsoft Edge, or Internet Explorer (10 or higher)) to set up through Amazon's Alexa page.
http://alexa.amazon.com/
For complete details, see the first section of "Amazon Help: Set Up Your Echo Dot."
Jul 15, 2017 | Smart Computers & Internet
How do I connect conventional speakers to Alexa?
  1. Set your Echo Dot and external speaker at least three feet apart. When Echo Dot is close to external speakers, it may be more difficult for Alexa to hear the wake word and other requests.
  2. Turn your external speaker on.
  3. Plug one end of an audio cable into your speaker and the other end into Echo Dot. All audio from Echo Dot now streams through your external speaker.
May 21, 2017 | Computers & Internet
I bought 2 echo dots i was able to connect one but the 2nd one wont connect
Check and make sure you follow all the steps it took to connect the first echo dot
Tips:
1. If the setup process does not automatically start, press and hold the Action button on Echo Dot for five seconds. Then, open the Alexa app, and go to Settings > Set up a new device.
2. If Echo Dot doesn't connect to your Wi-Fi network, restart Echo Dot by unplugging and plugging the device in again
Nov 26, 2016 | Office Equipment & Supplies
Televison & Video Logo
Top Televison & Video Experts
