Question about Dishwashers
My dishwasher still has water in bottom at end of cycle if I push cancel and drain it will empty
  • 209 Answers
SOURCE: Water doesn't drain
simple one this, just clear out the waste pipe and the inside food filter and the outlet pump, also check the outlet where the pipe goes (under the sink?) its a simple blockage somewhere, if i have helped rate me, and work safe remove the plug etc
Posted on Sep 16, 2007
aborcass
  • 2651 Answers
SOURCE: dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
  • 101 Answers
SOURCE: Dishwasher is full of water
The drain pump needs to be replace.
Posted on Apr 26, 2008
SOURCE: Bosch Dishwasher wont drain
Crazy! I have the EXACT same problem....sounds like it wants to drain...but won't ...Water has been stuck in the bottom for days now
Posted on Jul 18, 2009
QueenJLyn
  • 3 Answers
SOURCE: Maytag dishwasher not draining fully
Try cleaning out the air gap.  The air gap is not part of the machine, and is located on your sink. If this becomes clogged, it may cause the machine to not drain properly.  Also, I know you said you checked the drain hose and cleaned as far as the filter and chopper blade, but have you checked the lower filter?  There is a filter located underneath the machine that should periodically be cleaned.  To check this, you need to access the machine from underneath by removing the bottom vanity cover. Hope that one of these helps!
Posted on Aug 01, 2009
Why is there water standing in the bottom of my dishwasher after it has completed the wash and dry cycles.......
If water remains in the dishwasher after the cycles end, check the kitchen sink drain to make sure it's not clogged. If there's no clog, try pressing the Cancel button; most dishwashers run the drain pump when the Cancel button is pressed.
Check the dishwasher drain line, drain path and drain pump.
Oct 25, 2017 | Dishwashers
Dishwasher starts on its own (no house is not haunted). Start resume button flashes
have a service technician in as it appears to be a problem in the program board
could be moisture across the circuit board
Feb 06, 2016 | Maytag MDB7749AWQ Builtin Dishwasher
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Kenmore Dishwashers
Water won't empty. the bottom remains full
check to see if the water is draining completely. let it fill then drain and cancel unit check to see if this works if not check the drain pump. might also you will want to check soap,alot of times you can add jet dry and lets say a cascade with jet dry shine sometimes can over suds a machine this will cause the unit to keep rinsing to get the soap out,so when it finally ends there is extra water in unit. it is called over sudzing. let me know if my tip helped you.
Feb 23, 2010 | Dishwashers
Aug 01, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Ran on normal cycle when done 2 inches of water on bottom
Test by restarting the cycle and see if water drains if it does not then there is either a blockege in the pipe ,pump,or in the machine where the water passes out normally through a filter if you have checked and cleaned out filter and drain pipe and there is still no draining then listen to the pump if you can hear a humming niose then there is something in the pump itself and you need to take it out and inspect the impelar houseing remove what ever is there put back and enjoy if there is no noise and pump is clean then it is proberly fualty and nedd replaceing.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwashers Logo
Top Dishwashers Experts
