Question about Refrigerators
How do I reset my ice maker on French door sansung model rf26hfend
rickzilla
  • 706 Answers
SOURCE: Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Posted on Sep 15, 2008
MNTECH
  • 1543 Answers
SOURCE: error code IF or 1F not making ice model #795,77562... Sears/LG
You posted under an incorrect model number, so can only give general info. IF is a code for ice room fan. It is a fan located in a plastic box in the upper left hand corner of the freezer. The IF code shows up if the control board does not get a feedback signal from the fan telling the control board that the fan is running. I'd check to see if there is some ice blocking the fan blade. If that is not the case, you will need a meter to do further diagnostics to find out if your problem is with the fan motor or the control board. (note: when you turn the icemaker off, the fan will no longer blow cold air into the ice room, and all the ice will melt. Also, when the icemaker bin is full, the same basic thing can happen. Steady use of ice or dumping the bin will prevent ice from melting in bin.) The fan runs on 12 to 16 volts DC (variable speed), and the feed back signal is about 4.5 volts DC.
Posted on Jan 11, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Ice maker is not working anymore. Water doesn't fill the tub. Water dispenser out of the door is still working
I need you to double check the model number. Maytag has a service library at this link. http://www.servicematters.com/maytag_library/html/index.html
By placing the first 3 letters in the search feature it will take you to models like yours. Chose the correct model that you have and enter the number in the search. I believe that the water control valve on back of your refrigerator is the problem. Maytag is very good about helping their customers. Let me know if you have problems gettting the information you need, Thanks, Sea Breeze
Posted on May 26, 2009
heatman101
  • 43501 Answers
SOURCE: LG french door refrigerator ice maker
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Sep 11, 2010
  • 1891 Answers
SOURCE: French Door with bottom freezer Electrolux ice
sounds like the drive in icemker head is bad and not turning the timing wheel . the timing wheel controls the harvest and the water comming in ect . best to replace the icemker with ther kit . come with instructions . mm hope this helps . if more info needed i need the model # and ser of your unit .. feed back pls ..
Posted on Dec 11, 2010
Trouble shooting LG french door ice dispenser
LG French Door Refrigerator - In Door Ice Maker Troubleshoot
? 4:41
https://www.youtube.com/watch?v=rA1DhfTwuwM
Feb 4, 2013 - Uploaded by ExperienceLG
Ice makers are great, but not if it means you can't fit all of your food in the fridge. The Slim SpacePlus Ice ...
LG fridge ice maker troubleshoot/ repair. How to fix ice ...
? 8:06
https://www.youtube.com/watch?v=arJpFgMnvPY
May 19, 2013 - Uploaded by spartacus1234567890
The ice maker quit working in my LG refrigerator so I decided to take it apart ... LG French Door Refrigerator - In Door Ice Maker Troubleshoot ...
LG Refrigerator Ice Maker Not Working - Model LFX25960ST
www.repairclinic.com/RepairHelp/...Fix...-/LG-Refrigerator-ice-maker-n...
LG Refrigerator Ice Maker Not Working. LFX25960ST. The part(s) or condition(s) listed below for the symptom Refrigerator ice maker not working are ordered ...
Jan 05, 2016 | LG LMX28988ST Refrigeration : Refrigerator...
Have a tube w/rubber end hanging down in ice maker. Also a molded styrofoam w/ plastic loose in ice bin on model#253.70313211 French door bottom freezer. Wher does this belong and how do I fix it.
It fell of the bottom of your ice maker put your model number into repairclinic.com and you can find a pic or video that shows you how to put it back together
Mar 02, 2014 | Kenmore Bottom Freezer French Door...
heatman101
Sep 11, 2010 | LG LFC25770ST (250 cu ft) Bottom Freezer...
Why is my icemaker not working
My Samsung French-door frig had the same problem - try resetting ice maker - red button on the side of the ice maker. If that doesn't work call Samsung service - I had a bad circuit board which needed to be replaced by local Samsung repair service.
Apr 05, 2010 | Samsung RF265AA Bottom Freezer French Door...
The ice maker has quit. Water is working. Is there a reset button.
heatman101
5
Dec 15, 2009 | LG LFX25971ST Bottom Freezer French Door...
Samsung Ice Maker--Ice block and now no water flow...
Wait a few hours before you jump to conclusions. All depends on the position of the cam.
Aug 23, 2017 | Samsung RF265AA Bottom Freezer French Door...
Ice maker in Maytag French Door not working
replace the ice maker if the reset button has not done any good
Sep 16, 2009 | Maytag 25 Cu. Ft. French Door Bottom...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Ice Cube Maker
Sep 14, 2008 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
