Question about Brother Sewing Machines
I have a single head 9 needle brother 416 embroidery machine and the needles will not move up and down. the take up lever is not picking them up how can i fix this please
chrismyers67
  • 53 Answers
SOURCE: cotton breaks on Brother Embroidery Galaxie 2100 machine
Try turning down your top tension setting a bit. If its at 4 or 5, i would turn it down to about 3 ish. Cotton thread is more brittle than polyester and rayon thread.
Hope that helps :)
Chris
Posted on Jun 06, 2010
  • 109 Answers
SOURCE: brothers pe150 embroidery machine will not let the needle pick up lower thread
It sounds like the timing is off and needs an authorized repairman.
Posted on Aug 23, 2010
SOURCE: Brother VX-1120- The needle is not picking up bobbin thread.
I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
Posted on Oct 30, 2010
SOURCE: Brother PR600 embroidery machine, the needle
hook out of date
Posted on Jan 21, 2011
SOURCE: My Singer 5050 sewing machine won't let me
sounds like a part is damaged or jamed, the machine needs to be checked
to see what's wrong with it
Posted on Apr 16, 2012
Can a Brother 416A single head emb. machine be used for quilting and can I get longer needles for this?
First, use only the needles recommended for your machine unless you want a big repair charge.
Second, your machine is an embroidery machine, not a sewing machine. About the only way you can use it for quilting is if you want to embroidery designs on quilt tops.
Brother BAS 416A Instruction Manual Page 8
If you want to piece quilts, you might look for an older mechanical sewing machine (ie Kenmore, Singer, Viking, Bernina, etc) that you probably pick up for $100 or less. Basically, you can make quilts with a straight-stitch sewing machine, so zig-zag or multiple decorative stitches are not needed for quilting.
May 22, 2018 | Brother Sewing Machines
Why does the fabric get stuck in the feed dog plate?
try changing the needle it could be blunt
also make sure the top thread has not come off the thread take up lever
clean under the needle plate and in the bobbin are for lint
Mar 24, 2016 | Brother Se425 Computerized Embroidery &...
How do I change a needle on a brother 770?
same old way as all machines loosen the screw/clamp and pull it down
Feb 12, 2015 | Brother PE-770 Embroidery Machine
Brother embroidery machine
Hai, What type of your embroidery machine? How many heads and needles? If your machine 4 ,12 or 20 heads and 6 or 9 needle, you can use different color and designs.
Apr 10, 2014 | Brother Sewing Machines
Tajima embroidery machine troubleshooting
We are having a similar problem with one of our single head Tajima TMEX-C1201 machines. In our case the design runs part of the way, then the head jumps and continues running and ruins the work. Any feedback on this would also be appreciated. Thanks.
Jul 15, 2013 | Sewing Machines
My needle shaft stopped moving up and down while doing embroidery.
I've seen some of these machines where the pin that holds the needle bar in place falls out. If the take up lever is going up and down but the needle bar is not, this is probably the case. If the take up lever is not moving either, then you might have a broken timing belt or it has slipped off. You'll need a repair shop to fix it.
Apr 20, 2011 | Brother PE-150V Computerized Sewing...
(THIS IS A PREVIOUS POST BUT I AM HAVING THIS SAME PROBLEM. BUT THE TROUBLE SHOOTING THE NEEDLE HASN'T SOLVED THE ISSUE. ANY OTHER ADVICE?) I have a Brother CS-770. My fabric got pulled down into my...
Are you saying that you changed the needle? You cannot tell if your needle has a burr on it or not. Because if you did, you may have messed up your timing and need service because it will take special tools and know how to fix it. . Try another needle one more time (make sure that the flat side faces away from you) and different thread. Rethread with your presser foot up, then pull the top thread, it should move smoothly, now lower the presser foot and pull the thread, it should barely move. This should seat the thread in the tension discs. Also, check that you aren't using the wrong size needle for the task at hand.
Apr 16, 2011 | Brother Sewing Machines
My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
Make sure that your needle is put in the correct way, there is a groove in the front of the needle, check with your finger nail, this is usually to be facing you, and make sure the thread is going through the tension holder correctly do not have the foot down when you are threading the machine,as this stops the thread from going through the needle tension holder.
Sep 09, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brothers pe150 embroidery machine will not sew
If you tighten up your needle thread, reduce the tension of the needle thread.
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Mar 30, 2008 | Brother PE-150V Computerized Sewing...
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
