Question about Irons
I dropped my iron and the thermostat control dial broke. can i buy a new piece?
2 Suggested Answers
  • 794 Answers
SOURCE: Something dropped on the control wheel of my iron
Hi jfk0609,
The best place to bring your Rowenta Iron is on Rowenta's authorized service centers. I have list below that are located in Toronto. I included the phone numbers as well so you may inquire with them first the cost. Here's the list:
Butlers Service
249 Coxwell Ave. (South of Gerrard)
M4L 3B4 Toronto
Tel : 416-463-1164
Fax : 416-463-1166
North Avenue Road Appliances
1808 Avenue Road (North of Lawrence at 401)
M5M 3Z1 Toronto
Tel : 416-781-9389
Fax : 416-781-9380
Personal Edge
3302 Yonge St
M4N 2L6 Toronto
Tel : 416-483-7730
Personal Edge
50 Bloor St West Unit C-15 (Holt Renfrew Center)
M4W 3L8 Toronto
Tel : 416-925-3368
Personal Edge
218 Yonge St.(Eaton's Centre)
M5B 2H6 Toronto
Tel : 416-340-2820
Fax : 647-288-0129
Hope this helps.
Thank you for using FixYa.
Posted on Sep 14, 2011
Dropped it and now the bottom piece is cracked how do i change it
Irons are not repairable items unless they are professional use models. You just buy a new and better one.
Feb 28, 2016 | Irons
Why does it leak?
You answered you own question. She dropped the iron. That broke the water tank. Time for a new iron. It happens.
Nov 28, 2015 | Irons
I dropped it and broke the bottom blue plastic piece off. Can it be repaired?
there are special supa glues on the market that will glue it together
they are made by locktite and available from locktite agents and bearing supply shops.
Apr 26, 2015 | Oreck Cordless Steam Iron
Its giving my clothes black marks
It is to hot. read the labels in your clothing, what temp you are allowed to use and dial that in on the iron. Still burn marks, bring it back, because then the thermostat s not good.
Feb 05, 2015 | Tefal Irons
Where can I get replacement parts for Rowenta irons?
Fixya is unable to advise parts sources.
Aug 15, 2017 | Irons
Why light blinks then goes off when switch is still in the on position
The thermostat in the iron controls the temperature of the iron. The red light indicates when the power applied to heat the iron which is set by the temperature dial on the iron. When it reaches the correct temperature the thermostat turn off the power and that is when the red light switches off.
Jan 15, 2012 | Irons
I have a sharp cloths iron that will not heat up
I assume you mean that it will not steam???
TRY
1. Could be it's not getting hot enough?(Thermostat could be set too low)
2. The pipe into the tank is blocked? (try pouring a little boiling water CAREFULLY into the iron filler hole and try that)
3. The outlet jets could be totally blocked? (Buy a de-scaling kit from Wallmart or similar)
Failing that you may have to buy a new one. Wallmart or similar have cheap electrical appliances
Aug 04, 2009 | Irons
Auto Shut Off is causing the iron to not heat up
Try cleaning the lime out of the steam system. Lime buildup may be interfering with thermostat. Most likely is thermostat is wrong/broke and you should consider just buying a new one
May 26, 2009 | Sunbeam 4214 Iron
Irons Logo
37 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
