Can a region 1dvd play in the UK is flood the day the dam broke is region 1 and I don't understand want that means
  • 19 Answers
SOURCE: Convert US DVD in Region 1 to play in UK Region 2
Please go to codemasters.com , type in the details of your dvd player, there will be several region code hacks ,follow the instructions and this should work for you, basically you are needing to make your dvd player a multiregion player. all dvd players are multi region at time of manufacture, but they are code set for the county that they are shipped to, hopefully this should help. you can also go on to google type in Hack for whaterver your dvd player is and you will get a region code there.
best Wishes
jimba
Posted on Jul 13, 2009
boltthedog
  • 24 Answers
SOURCE: i just bought a dvd player (avh-p5100dvd) from
look online for avh-p5100dvd multi-region hack
Posted on Sep 19, 2009
SOURCE: unlocking region code panasonic dmr-ex77 dmr-ex87
I have a panasonic dvd recorder. Model dmr-ex87
I was going through the options for the remote control and i selected dvd 3..Well this has caused problems as the remote only displays dvd3 when you press any buttons on the remote. How can i get it back on dvd1??
Posted on Feb 04, 2010
muntejaya
  • 10421 Answers
SOURCE: can i change the region
Hi there, please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay_tyh67
Posted on Feb 27, 2011
BElectric
  • 1140 Answers
SOURCE: I have bought a Philips
This player can be unlocked, but I'm not 100% certain whether the unlock method works with players sold in North America, i.e locked to Region 1. These players often use different software/firmware which disables the unlock code used for players locked to other regions. Some have an additional chip which prevents them from being unlocked full-stop.
1. Power ON the main unit with no disc inside
. Press the SETUP button (on the top of the player) to open the setup menu
3. Navigate to the PREFERENCES menu using the button below the screen
4. Press NEXT>, PREVIOUS, NEXT>, PREVIOUS, NEXT>, NEXT>, PREVIOUS
(NEXT> and PREVIOUS are on the top of the player next to the SETUP button. Don't use the menu navigation buttons below the screen for this.)
5. The current Region of the player should be displayed on the screen
6. Use the menu navigation UP/DOWN buttons (below the screen) to change the region. Region 0 is region-free.
7. Press PLAY/OK (below the screen) to confirm the region selection
The player should now be unlocked and able to play discs from all regions.
Please follow these instructions carefully. If it doesn't work the first time, switch the player off then start again at step 1 and try a couple more times. If the current region does not display after step 4, then the player can't be unlocked due to being a Region 1 version.
Please note: Unlocking a DVD player may invalidate the warranty and some DVD players have been damaged through failed attempts to unlock them. Unlocking the DVD player is attempted at your own risk.
Please try this then let me know if you need further assistance. I'd appreciate it if you could let me know the outcome for future reference. You can reply to me by clicking on "Add a Comment" below your question.
Regards, BElectric
Posted on May 06, 2011
When purchasing a DVD I don't understand what is meant by 'region'. Please tell me which 'region' the UK is
The UK, Europe and Japan use Region 2. Region 1 discs are used in the USA or Canada. These codes control where the discs can be played, and you cannot normally buy DVDs in a different region and play them at home.
26364762-n5uv4pl0imrm51spsuhjadcc-3-5.png Hope this Helps?
Nov 20, 2016 | Televison & Video
Hi i have a lg bg550 blueray dvd and i have just got a region1 disc is there a unlocking code for this model so i can play region1 and region 2 discs regards **** towner
Could not locate this model but this may help:
Power up the Player, press pause;
Type in 314159 on your Remote Control's Keypad;
This should bring up the Region Selection Screen;
Select the Region (1-6) that you wish to view on your Remote Control's Keypad, sit back, and enjoy ;-)
Two important features with this player.
Firstly, in addition to the first hack listed above, instead of choosing a Region 1 through 6, you can choose to set it Region 0, or region free. This means you will not need to change it every time you put in a disc of differing regions.
Also, if your TV is not capable of both NTSC and PAL playback, you can adjust the format of the DVD player signal by flicking the System Select switch on the rear of the player. Without changing this, the region free hacks listed above may not display correctly if you are using an older TV
To enable VCD, it works for this model as other LG players:
1. Power on the player with no disc in the drive.
2. Press Pause on the remote control.
3. Using the remote control, key in the following: 1, 4, 7, 2 (the
characters 01 47 should appear on the display) [If your player is a non UK
model, this number will probably be different - don't worry]
4. Press the UP arrow three times (the characters 04 Fd should appear on the
display)
[This number may be different depending on the configuration of your
specific model - don't worry]
5. Press Program, 6, Program, 5 (the characters 04 FE should now be
displayed).
6. Press Enter (the display should flash briefly).
7. Press Return.
8. Power the player off and then back on.
9. Play a VCD!
http://www.videohelp.com/dvdhacks/lg-5500n/4153
Jul 25, 2011 | LG BD550 Blu-Ray Player
I bought a DVD from the U.K., but it's not working on my DVD at home. I live in the U.S. I need some help. How do you make a foreign DVD work on our models?
The answer is generally you cannot. The recording industry refused to produce DVDs until the DVD player manufacturers agreed to a regional system, whereby DVD players sold in a particular region could only play DVDs marked for that region or marked "Universal" or "Region Code 0" (this is supposedly to discourage illegal copying). Your best bet is to use a computer DVD player set up for Region 2 (US is Region 1), then connect the video output of the computer to the monitor input of the TV if your TV has one (either VGA or DVI), or just watch it on your computer.
Earlier models of DVD players would allow you to change the region up to five times, but would permanently lock in the region set on the fifth change. Newer models don't even have that option because it was relatively easy to hack the region change counter. There is an "under-the-counter" DVD player hacking industry in Europe, but there is little demand for that in the US - partly because US recording industry lawyers can be even more bothersome and expensive to deal with than European bureaucrats, and partly because few people here obtain out-of-region discs.
Jul 04, 2011 | Televison & Video
Playing DVDs
NoThese days most of the companies are producing Region 0/ALL DVDs If you can get them OR buy a dual region DVD i.e. Region 2/4 which can play on both the regions. Most of the DVDs produced in India are multiregions. Choice is yours now
Apr 17, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Region 0 DVD's will not play
I understand that what you call 'region free' is Zero! Therefore this discs you are trying are not zero. Try inputing different numbers to get them to play.
Region Free is a myth!
Dec 08, 2009 | Electronics - Others
What does it mean when my dvd player says wrong region??
DVD's are coded to play in different parts of the world. Each DVD player is set up to recognise these codes. Most are set up to recognise only the region code of the area it was made for. For example Region 1 is for the USA and Region 2 is UK and parts of Europe. A DVD player made for the USA market would not be able to play any other discs with a Region code other than 1. And so on... This was done for the film industry benefit so that films can be released at later dates in different parts of the world without everybody seeing it on DVD issued in the USA.
However most DVD players can be "hacked" by a combination of keys allowing the user of say a Region 2 player to change it to another region. Some can also be changed to Region 0 which means it should play any disc.
How to change the Region code can be found by putting the model number of the DVD into a search engine and the words 'region code'. Some can be found on this site too.
Dec 04, 2009 | Electronics - Others
Player won't play legally imported DVD's
Hi, guessing you are from the UK? Different countries operate different regions for dvd's for instance the UK dvd players are set up to play region 2 discs, and US dvd players are set up to play region 1 discs.
This is because dvd release dates are different around the world and this stops people buying a dvd in the US and bringing it back to the UK and selling it before its official UK release date for example.
Your choices are either to play the dvds on a PC where often the dvd software will allow you to change region a number of times (be careful though as some players will let you change region say 5 times and then be locked to that region)
Or to get hold of or buy a multi region dvd player which plkays dvd'd regardless of their original region
Hope that makes sense, good luck
Jul 20, 2009 | Electronics - Others
Live in region 2 want to play region 1
To unlock all regions:
1.Press Setup on remote
2.Scroll down to Lock icon
3.Press 0000000
4.Regionfree!!!
Jay
Aug 26, 2008 | LG RH1999H DVD Recorder/HDD Recorder
Philips 7" DVD portable player
The PET702 will be a region 5 machine, whereas the UK DVDs are region 2.
DVD players from a particular region are designed to play only DVDs from the same region, due to copyright and distribution rights in each country or region.
However the PET702 can have the region protection removed by making it multi-region:
Switch on the PET702 and Open the tray.
Press SETUP button on the remote control, which will bring up the menu.
Highlight "PREFERENCES" and press OK.
Press [2], [5], [2], [3], [1], [5], [LEFT], [DOWN]
The screen will show: "Region Code: 2"
Press [1-6] to manually set the region OR [0] for multi-region.
You will now be able to play DVDs from anywhere in the world.
This is particularly useful, because region 1 DVDs from the US often come out when the movies are still in the cinemas over here. Region 1 DVDs can be bought perfectly legally by mail order or from the internet.
May 07, 2008 | Televison & Video
Programmed for region 2....Need to change to 1
Q: What is Regional Coding enhancement(RCE)?
A: It's a digital enhancement added to some Warner Bros and Columbia DVDs to stop region 1 (R1) DVDs from playing on Region-free DVD players.
Q: What's the difference between Region Coding and RCE?
A: Regional Coding enhancement(RCE) is an additional layer of protection which some studios have placed on select REGION 1 DVDs to prevent them from playing on region-free or multi-region players. Region Coding is a part of the DVD spec which divides the world into 8 regions:
Region 1: U.S., Canada, U.S. Territories
Region 2: Japan, Europe, South Africa, and Middle East (including Egypt)
Region 3: Southeast Asia and East Asia (including Hong Kong)
Region 4: Australia, New Zealand, Pacific Islands, Central America, Mexico, South America, and the Caribbean
Region 5: Eastern Europe (Former Soviet Union), Indian subcontinent, Africa, North Korea, and Mongolia
Region 6: China
Region 7: Reserved
Region 8: Special international venues (airplanes, cruise ships, etc.)
Basically, DVDs released in each region will typically only play on players sold in that region. IE a DVD released in the UK *Region 2* would not play on a player sold in the us *Region 1*. You can tell what Region a DVD is coded for by looking at the back of the box for a Globe with a number on it. The number correlates to the region list above. If a DVD is listed as 'Region 0' it means that it isn't coded for any region and should play on ALL regions players.
Dec 14, 2007 | Philips 30DV693R 30 in. TV/DVD Combo
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
