Question about Craftsman Garden
I have a craftsman lawn tractor model # 917.289031 it turns over but won't start why?
    Loyalty:
    Visited the website for 30 consecutive days.
  • Craftsman Master
  • 1,419 Answers
Remove the spark plug spray gas in the cylinder replace plug turn it over if it starts you know it is fuel supply check filter if ok clean carburator hope this helps ps be sure you have no spark before do all that work .
Posted on Dec 16, 2017
  • 49 Answers
SOURCE: mounting snow blade to lawn tractor
It attaches the the front of the tractor. Similar to a plow to a truck. If you don't have the brackets, you will need those, or make your own. You can see a picture of the brackets if you go to sears.com. Click on the PartsDirect link at the top, and enter the blade model number.
Posted on Feb 05, 2009
  • 246 Answers
SOURCE: owners manual for a craftsman model 917255812 lawn tractor
Hello:
>>You can Use the Site Addys at this Site Addy; http://www.yetmans.mb.ca/antiques.html to Search and Locate New/Used Parts or for Manuals for this Unit.
Respectfully
John
Posted on Apr 21, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
  • 376 Answers
SOURCE: large belt routing for crafstman lawn tractor
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number that is under the seat. If it's a lawn tractor, it will start with 917. That will get you to all the diagrams of the mower.
Posted on Jul 02, 2009
  • 130 Answers
SOURCE: change the v-best on a craftsman 42' mower 6 speed transaxle lawn
if your going to do this get a book its not going to be easy.so you need a book i say take to shop.let me know
Posted on Jul 22, 2009
Mower Won't Start
Check your start 20-30 amp fuse, Should be on right side of motor, sitting on it.
May 29, 2013 | Craftsman 46" 21 hp Lawn Tractor
Craftsman lawn tractor turns over but won't start
i would check the switch on the brake/clutch it has 2 switches built into one jump it with a paper clip to test it
Jul 31, 2012 | Craftsman 48" Cut Riding Lawn Mower Deck...
I HAVE LAWN TRACTOR WILL NOT DO NOTHING
If you mean it won't start, take a look at this tip I wrote on the no start problem.
Oct 09, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman lt 1000 riding lawn mower and it runs, but it won't go into gear it goes into gear, but clutch won' engage the gear.
Look under the mower to see if the drive belt has come off or broke. It is the belt that runs from the bottom of the engine to the rear axle.
Oct 01, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman 18.0 42" lawn
First check to make sure you can turn each blade by hand, with the mower off. If neither blade spindle is frozen remove the deck and make sure all the pulleys move freely and function like they should. The cable should have been operating a spring loaded pulley arm that applied tension to the deck belt to make the blades function. Some times build up with block that from moving or rust will make it stick.
May 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
52 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
