Question about Car Audio & Video
DTT3500 circuit diagrams model MS0020B. I would like to repair my amplifier. woofer circuit not working,after cleaning cicuit with brush it wont power up.amp worked sans woofer problem.
  • 30 Answers
SOURCE: Cicuits Protection
You have a power supply circuit problem,you need a qualified serviceman near you.
Posted on Feb 18, 2007
  • 84 Answers
SOURCE: circuit diagram of 1400 watt woofer amplifier
www.the12volt.com/ subwoofer wiring diagrams and then find out what ohm of sub u have and how many voice coils and what ohm your amp is stable at.
Posted on Jun 14, 2009
  • 1015 Answers
SOURCE: Sony X-Plode amplifier. NOT working
It is possible if the model amp you have is bridgable to 1 channel. Usually when you bridge an amp you will need to hook one wire to the positive side of one channel and the negative side to the other. You will need to consult you user manual for the amp or get the manual from the sony website for instructions on how to bridge the amp or if the amp is even bridgable.
Posted on Oct 11, 2009
  • 4234 Answers
SOURCE: HI, I have a Teac
If you are looking for the pinout diagram for this, go to the link below and enter: stk4191-2 in the part search window. This will get you to the PDF of the specs for that part.
Dan
Link: http://nte01.nteinc.com/nte/NTExRefSemiProd.nsf/$$Search
Posted on Aug 17, 2010
  • 21 Answers
SOURCE: I have a JVC TH-M303
A defuser is burned.
Time for a new sub.
Posted on Nov 19, 2010
Help me with a subwoofer circuit
sub-woofer circuit Michael, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
100W Subwoofer Amplifier Circuit Diagram Working and Applications
Subwoofer Filter Circuit
22 Watt Car Subwoofer Amplifier Circuit Diagram
subwoofer circuit Google Search
Jun 03, 2016 | Audio Players & Recorders
Subwoofer is not playing
It is hard to say. The sub-woofer has its own amplifier, although it is supplied the sound data from the main amplifier. It could have a problem with the battery power circuit (Sub-Woofer Amplifier Connector Pin 6, LIGHT GREEN/VIOLET) or it could have a problem with the GROUND circuit (Pin 2, BLACK/LIGHT GREEN) Or it could possibly not be receiving the signal from the main amplifier (Pin 7, BROWN/ORANGE "+"), (Pin 8, RED/BLACK "-"). Or it could be that either the sub-woofer speaker is blown, or the sub-woofer amplifier is defective.
There is also a "High Audio Mute" circuit that connects between the main amplifier and the sub-woofer amplifier.
Mar 06, 2012 | 2000 Lincoln Navigator
It wont light up and when i hook up the kicker it goes hay wire with out put but its not the music
If you are hundred percent sure that your sub woofer is working correctly, then it would indicate that the amplifier is faulty. Component failure inside will probably be the cause of your problems. Take it in to a qualified repairer to sort out.
Aug 12, 2010 | Power Acoustik TS620-2 Car Audio Amplifier
I asked earlier about my pioneer amplifier sa-1270 circuite fuse but the circuit I need is PD 4088-A7507H48 and LB 1214. Do you know where I can find these cicuits?
This may work but i always take my amps to a tv repair place. They normally dont work on these but i convinced him to do it. He fixed both amps i took to him. Try ur luck
Oct 12, 2009 | Audio Players & Recorders
My amplifier turned off while playing and wont turn on at all now
Hello, it sounds like you shorted the outputs of your amp or the power supply mosfets shorted. Very common when people have the music at a loud volume. Does the protect light come on? If not then the power supply is probably shorted not letting the protect circuit get any voltage. Some amps do this and other amps if the power supply shorts have the protect cicuit built in such a way that if the power supply shorts out the protect circuit still works. Cause you checked all wiring and redid it and no fuses blew then this is your problem. I repair amps everyday for a living. ?Most of my out of state customers are from fixya.com. I'm the cheapest amp repair business you'll find. If interested send me a private message letting me know what kind of amp it is, name and model number, and i'll get you back up and running with warranty.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Aug 23, 2009 | Car Audio & Video
Whirlpool oven: oven bulb popped and oven wont work. I already replaced the bulb. Does it have a reset switch? The stove top still works fine. The gas wont come on in the oven so that I could manually...
Sounds like you have an open cicuit in the oven power. The control for the gas uses the impedance of the hot surface igniter. Check for a circuit breaker. The wiring diagram should be inside the control panel cover.
Jul 07, 2009 | Kitchen Ranges
Circuit diagram of 1400 watt woofer amplifier
Jun 10, 2009 | Beyma WOOFER, 1400 WTS, 18" => Model...
Fried Woofer
The problem are worsen that before. It is wisely to replace both left and right amplifier
IC, but make ensure that the power supply feed a good amount of voltage to amplifier,
Also a strong good signal. Be sure to measure it.
r_ic7
Jun 22, 2008 | Alesis M1-Active MkII Main / Stereo...
Cicuits Protection
Nov 27, 2006 | Technics SUV500 2-Channel Amplifier
Car Audio & Video Logo
51 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
