Anyone know the air conditioning code for a Jocel air con unit please?
  • 254 Answers
SOURCE: air-conditioning; error code: 425
Posted on May 30, 2008
Posted on Sep 21, 2008
  • 30 Answers
SOURCE: panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Posted on Jul 18, 2009
SOURCE: There is a buzzing noise coming from the air con unit
if everything is running may just be contactor,if compressor is running not fan turn it off call service tech out(Fan motor bad)if fan is running but no compressor turn it off call service
Posted on Jan 06, 2010
  • 66 Answers
SOURCE: wiring diagram needed for carrier air con unit
Here ya go:
Posted on Jun 30, 2010
I have a mr slim r410a air conditioner. I keep up with filter changes but I still get an inordinate amount of dust all over my house. Anyone know what the problem might be?
Does your air condition have switch or some kind slider that has inside air or outside air on the unit, cause if its on outside air intake then that's why you have dust coming thru your air con and throwing dust cool air around your unit or house, switch it back to inside air to forever keep out that dust....!!!!! Thank You
Aug 13, 2015 | Filter Heating & Cooling
The air con.. says El and not the 72 like normal what can it be
Here is a tip that gives a further explanation of that E-1 code. The causes ofthe E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening withyour window air conditioning unit and give you some things to try to help youget your problem resolved.
E-1 Code on Window Air Conditioning Units
Aug 14, 2011 | Danby Heating & Cooling
Hi I HAVE A DIMPLEX AIR-CON It was already here when I moved into this house but lately after it been for on about 5 mins it stops and it display a code of P2. I dont know how to get hold of a manual...
If your model is a portable AC unit, the P2 indicates that water needs to be drained from the tank.
Turn the unit OFF and unplug it, before draining the water from the lower tank into a shallow sided pan capable of holding at least 1 quart of water. Once it has completely drained, reinsert the drain plug, plug the unit in and turn it ON. The P2 Error Code should have disappeared. If not, press the ON/OFF button twice.
I hope this helped you.
Jul 15, 2011 | Heating & Cooling
Show me where the filter is located
dear sir /madam
please know what is type your air-con i mean widow type or split type or Central air conditioning's unit .if your air con is window type air conditioner then remove cover (grill) and find there is air filter if your air con split type of then open its cover there down side of cover filter located
if air con is central cooling unit the find out your filter in duct side i mean air blower side where fresh cool air going to your room .
use this method i hope you will find solution of your problems
thank you
please vote!
Sep 06, 2010 | Heating & Cooling
LG S12AWN-4 manual
Im trying to find out roughly how old my air con unit is, can anyone help?? It's an LG S12AW 3.5kw High Wall Split Air Conditioning System
Aug 22, 2010 | Heating & Cooling
English Instruction Manual for a Toyo TA-09CHS Split Air Con Unit
I bought two TOYO split air conditioner in 2009. They are awesome, the best quality split air conditioner in Japan. I have two manual in English and I can mail you one. Please let me know how to mail it to you.
Jul 20, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Jun 24, 2008 | Heating & Cooling
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
