Question about Worx Garden
Have two worx 20v batteries that are fully charged but when I use them they stop giving power to my trimmer and blower. I have had these for more than two years. Why do the batteries got out?
    Top Expert:
  • Worx Master
  • 40,263 Answers
Some battery types are not very durable.
Posted on May 13, 2017
My blower doesn't have reaction while I put in the recharged battery(20v) after store in garage for one winter.
see if you can rotate the blades with your finder sometimes that's all it takes to get her going
Apr 13, 2015 | Garden
I have a worx 18v lithium battery trimmer that turns off after some seconds of use. The battery is fully charged. Seems like the current stops (maybe child protection feature related?)
Your battery may be faulty. When the new lithium batteries get to a certain point on the charge, they just shut off. You can't continue using them till charged.This feature may be shutting the battery off early.
Mar 26, 2015 | Worx Garden
How long should a fully charge battery last on WG250E Hedge Trimmer
This is the info i found on WG250 battery . It says up to 50 min below in the features. Hope it helps
The WORX WG250 hedge trimmer incorporates an 18-volt 1.7 Ah Ni-Cd battery pack. You can use this battery pack with other WORX Ni-CD PowerShare tools. The included charger takes about an hour to restore a dead battery to full charge.
Cordless Hedge Trimmer 18v Worx WG250E jQuery(document).ready(function($) { $("a[rel=product-image-gallery]").fancybox( { 'transitionIn' : 'elastic', 'transitionOut' : 'elastic', 'titlePosition' : 'over', 'titleFormat' : function(title, currentArray, currentIndex, currentOpts) { return 'Image ' + (currentIndex + 1) + ' / ' + currentArray.length + ' ' + title + ''; } }); });
  • Wall mount bracket
  • 3 position adjustable front handle
  • overmould soft grip for user comfort
  • Quick release handle
  • Double insulated
  • Volts: 18
  • Blade length: 510mm
  • Cutting capacity: 14mm
  • Blade action: Dual
  • Run time: Up to 50mins per charge
  • Charge time: Up to 1 hour
  • Machine weight: 3.1Kg
  • Comes with one battery and a charger
Sep 13, 2011 | Worx Wg250 20inch 18volt Cordless Hedge...
My trimmer wont start. thought it was battery put a new one in worked for a few minutes and then stopped working
your batteries aren't charging fully, check them fully charged with a volt meter,, fully charged they should have a reading of 18.5 volts, if not they are not charging, and either the batteries have used up their life, or your charger is on its way out
Jul 15, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
My worx will not stay charged... the charger goes green after about 10 minutes and only runs for about 5 minutes...
it sounds like the battery has seen better days. a battery will get a "memory" and after while it could fully charged as far as the charger know but only hold a little charge. with the advices in batteries they shouldn't do this but they all do wear out of time. I would get a new battery, and everything should be just fine. With the any new rechargeable battery you want to make sure that you charge it completely and drain it the whole way before recharging.
Best of luck
Jun 23, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
I used my Worx trimmer successfully last season. This spring when I went to use it, it would not hold a charge. The light shows green on the charger but the trimmer only works for about a minute before...
Your battery is shot. I had one of these, the batteries are really cheap and don't last long. If you can afford it, ditch the Worx and buy a quality trimmer at your local hardware store. If you are short on cash you can buy new batteries online.
Jun 06, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
My trimmer does't work longer then 20 minutes. I can only get part of my lawn done. it takes 3 days to get it done with my trimmer.
I hate to have to break the news to you, but it probably never will. The batteries sold with the Worx trimmers are very cheap. I recommend either buying a few extra batteries and keeping them all charged so you can finish the job or buying a gas or plug in trimmer.
I had one of these last year and there is just no way you are going to get any more out of it. Sorry.
Jun 02, 2011 | Worx GT (10") 18Volt Cordless LithiumIon...
Battery will not fully charge and red light blinks continuesly.
Have you tried to have the battery tested,and or the charger,its definitely one of those,BUT be careful to check what they cost before replacing any parts,your supplier should be able to help,rgds
Sep 25, 2010 | Worx GT (10") 18Volt Cordless LithiumIon...
Lithium battery for 18v trimmer keeps failing, can not seem to get more than 5 hours total out of it.i charge it inside at 80 deg..
I don't think there's anything wrong with this. 5hrs for a high current tool is actually really good! A quality 18v drill can only drive a few hundred screws at most before needing recharging. And that might be 30 mins...
Personally, I recharge all my tools after each use. The charger for this item will have a 'trickle charge' when the battery is fully charged. This will keep it topped off, and ready for use. It won't hurt the battery to keep it fully charged at all times.
Hope this helps!
If this has helped with your solution please give me the appropriate thumbs up. Thanks, and good luck!
Aug 13, 2010 | Worx GT (10") 18Volt Cordless LithiumIon...
Garden Logo
47 people viewed this question
Top Worx Garden Experts
Tim Whalen
Wayne McNeil
john milligan
Are you a Worx Garden Expert? Answer questions, earn points and help others
