Question about SimpleTech SimpleDrive 160 GB External USB 2.0 Hard Drive
Simpletech 160mg pinifarina wont work
I recently replaced my power supply on my tower. Now when i plug my simple drive 160gb pininfarina in, the computer dosent reckognize it, and it dosent show up anywhere. I get a bubble saying it may not run properly. Ive tried plugging both usb in at the same time, and all the ports on my comp work because i tries them with my flash drive. The red light comes on on the drive, but no green light....i need help!!
I had the same problem. I got an external usb 7 port hub that had to be plugged into and outlet. That way when i plugged in the drive to the usb port it got its power form the outlet not the computer. Now it works perfectly for me.
Posted on Aug 10, 2009
  • 71 Answers
Sounds like a corrupt driver. Go to device manager, and see if the USB tree has a yellow exclamation, if yes, uninstall USB driver and reboot.
Posted on Jul 26, 2009
I plug in both usb connectors, and nothing happens. Device does not appear on laptop. Pinfarina 160GB, red case.
Try connecting it to a different computer -- if it still fails to work, then there is nothing wrong with the computer; the fault is with the SimpleTech unit (either the USB-to-disk-drive adapter, or the disk-drive inside the case).
Aug 26, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Lost the power adapter for my SimpleTech 160GB external hard drive. Where can I get one? DL
You can use any 12V, 2A tip positive adapter. You can find one at Best Buy, Radio Shack, etc.
May 09, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Cannot get computer to recognize my simpletech external hard drive. I have windows 7
A problem I commonly have is if the external drive is plugged in to a non powered usb hub the unit does not have enough power and will not be recognised, ensure it is plugged directly into the pc tower or if you have a laptop try an alternate usb port as some may not be powered.
Mar 07, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
I just recently bout a 250gb simple tech external drive. I came home installed but it wont show in my computer
You might try a different cable or use a USB "Y" cable to supply enough powere for the drive to work, as some computers have difficulty providing enough power from a single port. If you need more help, please call HitachiGST Tech Support M-F 8AM to 6PM PST at 1.888.426.5214 and a technician will be happy to help you.
Feb 02, 2011 | SimpleTech Signature Mini 160GB External...
My SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive suddenly disconnects a Reconects again....
You may have a power supply that is defective or is failing. Try another power supply, 12V, 2A, center pin positive.
Jan 24, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
Device no reconized , my W7 don't want install drivers for simpledrive 640 GB pinifarina
The usb device not recognized error generally means the right drivers are not present on the computer. I would expect that Windows 7 can recognize most external HDD automatically, but you might need to install a driver for it.
But try the disk on a different USB port, or even computer, to see if it still works properly.
Jun 28, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
Simpletech pinifarina 500GB external drive - unable to access
A few things to check but assumes USB for other interfaces similar steps may be followed
1. ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer.
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply (Dont use any other unless you know it has both the same voltage and current rating eg. 12V 500mA anything rated below that would not work properly)
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select computer management.
Now select Disk Management and expand the window.
Your drive should be listed here (if not then you need to check your computer hardware has not got any issues before proceeding)
If your drive is listed and says healthy then right click on it an select Properties, click tools and then error checking, Check now, tick the two boxes and then start.
This will attempt to fix any errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed ut did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. when it is done restart your computer and you should be good to go.
Aug 16, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
SimpleTech SimpleDrive Pininfarina 320GB Power up problem
It could be that it's internal power supply burnt out,
in which case the drive itself could still be fine.
Try opening up the external case, and removing the drive.
Once you do, plug it in to your computer directly using its SATA cables, and see if that works.
Hope I helped,
Tom
Jun 21, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Simpletech 320GB BOM No.: 96300-41001-012 is new has never worked
The original power supply is "SB2D-020-1HA SIMPLETECH AC ADAPTER 12V 1.5A FOR EXTERNAL HARD DRIVE" . Just find a replacement with the correct size plug (center positive) that supplies 12v DC at 1.5amps (1500ma)
Mar 10, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
SimpleTech SimpleDrive 160 GB External USB 2.0 Hard Drive Logo
501 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
