How can I start my TV on regular channel , what will I do?
What do i need to get regular channels on the tv
How to get regular TV channels?
Your HDTV should have a digital TV Tuner (ATSC) which may need an indoor antenna. Change your TV's input selector to TV or Antenna or Digital (probably one of those three) and scan for channels. If you don't get any channels, then you do need an antenna. Probably another $10.
How to get basic channels on new HDTV without cable - HDTV ... What do need to get regular channels on the tv Google Search
Dec 12, 2016 | Televison & Video
How can I program TV for regular channels or air?
If your TV has a channel selector, you probably will find there is not much to see now that the world has gone digital. You may have to get a set top box to convert digital signals for viewing.
Mar 22, 2016 | Televison & Video
My son bought this TV and had it hooked up to a cable connection with an HDMI cable and it worked fine. He gave the TV to me and I hooked it up to a basic cable connection with no cable box. It does not...
If your TV has an On-screen Menu you should be able to access your Tuner controls. Run your auto channel scan and you should pick up your "regular channels". You may be able to de-select the odd channels and show only the ones you want to use.
Oct 03, 2011 | Westinghouse LTV32W6HD 32 in. LCD...
Describe how to program channels on lg tv
Very simple -
You will need to find a feature that says 'Auto Tune'
This first will ask you to select between:
1) Regular TV - off air antenna - connection
2) Cable TV - connection
3) DSS TV - Connection
If you aren't ready for digital TV with your antenna or cable you may get very few channels.
Nov 17, 2009 | LG 42LC2D 42 in. LCD HDTV
Sony bravia-unable to tune in video channel via dvd
thethe wires have to run out of your cable box into the dvd recorder then back out to the tv,try rehooking it up
May 19, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Switching singnal
If you are using an antenna or regular cable without a cable box, put the tv on an analog channel. Go into the menu. Select the middle icon at the top of the screen. Go down to the TV/CABLE line. Select either TV (for antenna) or CABLE (for regular cable) on the right. Go down to AUTO CH MEMORY and press the volume+ (right arrow) button. Wait for the channel search screen to clear. Check all of your channels using the channel up button until you come back to the channel you started on.
Feb 28, 2009 | Sansui 27" TV
Tv/remote input problems
Try plugging your cable box in using a/v cables (red,white,yellow) and see if you have a picture on a different input from the box. If so, go into your general settings in the box and change the output channel to 4 instead of 3. Then try your TV on 4 and see if your picture comes in. I have seen TV tuners go out on just one channel before.
Feb 24, 2008 | JVC AV-27230 27" TV
Remote control codes
how do activate sharp tv to a comcast remote to change the regular channel on he tv im trying to turn to channel 3 but when i turn from the tv it skip from 2 to 5 then so on.
Feb 19, 2008 | Televison & Video
Sony trinitron tv KV-32LS36U changing channels
You may have a control button sticking either on your remote or on the front panel of your set. I have run in to this on several sets. When this happens, some really strange things will happen including problems like you're having. Stargazer
Jun 13, 2007 | GE 32GT660 32" TV
Televison & Video Logo
Top Televison & Video Experts
