Question about PANDIGITAL Tablets & eReaders
Wish to know whether pandigital photoframe can be used with wifi and bblue tooth,have guide version CD8-
Samsung laptop showing connected to wifi but when try to access wifi says problem with connection
Try using the troubleshooting option that usually is offered when you get a network error message. If still does not work after that need more specific info on exact wording, Windows version, whether all wifi connections affected, etc.
Jun 04, 2016 | Samsung Galaxy Tab Tablet PC
How can I setup blue tooth on the tablet to talk to my cell
Go in to setting look for blue tooth press it, go to your phone settings and look for the same thing on both units press Pair with device. At this time the blue tooth should turn on, blue tooth then should allow both units to hook up with each other FYI pass word should be 0000. if you need it
Mar 14, 2015 | PANDIGITAL SuperNova
How do I get my wifi to connect to the pandigital
It sounds like it cant connect if its rescanning, try rebooting both devices and try again. If that fails try another wifi(another place with wifi) area to test if its the device or the wifi.
Dec 28, 2014 | PANDIGITAL SuperNova
Why does my pandigital 8 android 2.3 not want to connect to wifi
This can happen when you are using a new wireless security authentication and a older device such as 2.3
We would suggest two thing
1. No Reset button,1)You have to press power and volumen up @ same time and realese power when turn on.2)presspower and volume up and select wipe.
2. going to a different type of security on your router to see if you have success.
Dec 26, 2014 | PANDIGITAL SuperNova RR80B455 Internet...
Need user manual
You can find the Quick Start Guide and User Manual for Pandigital Novel eReaders here: www.
Jan 11, 2012 | PANDIGITAL Tablets & eReaders
Pandigital novel 7" WHITE ereader wont turn on.
You can try pressing the reset button with a straightened paperclip of pin. If that doesn't do anything removing the back and unplug the battery. Leave it unplugged for a minute or two and reconnect it. Be careful unplugging it as you don't want to put to much force on the wires. You can use a small screw driver or tweezers to pry on the plug. The white plug here is what you're locking for. See if it powers on and hopefully it does. If not you may have to contact Pandigital.
Hope this helps
Mar 12, 2011 | PANDIGITAL Digital Book 843967071153...
Tablets & eReaders Logo
29 people viewed this question
Top PANDIGITAL Tablets & eReaders Experts
Colin Stickland
Colin Stickland
Are you a PANDIGITAL Tablet and eReader Expert? Answer questions, earn points and help others
