Question about Sharp Ovens
I have an ancient Sharp Carousel Alacard microwave. Part of the door seal has fallen off and broke into pieces when it hit the floor. Can we still get these parts or should I get a new microwave
The oven was purchased in 1977/78
  • 146 Answers
Ancient is the key here, do you want to keep it sentimentally or build a new relationship with a new , young better model? The seal is essential to keep users safe from not use if seal is damaged. Microwave is a klystron type transmitter used in radar. Have repaired and ck for escaping rf energy.if you go that route.I'd go new.
Posted on May 13, 2017
After a powercut my microwave has managed to lock itself! How can I unlock it? Really urgent as i have a small family, my husband is in Afghanistan and I need it all the time for sterilization etc. ...
Hi Sally,
I have a sequence for my Sharp Carousel that will lock or unlock. Press "Auto Start" > "1" > "Stop"
If you have a different microwave, leave the unit manufacturer and make and I will do my best to find the answer for you
Sep 21, 2011 | Ovens
Microwave heats fine, finishes timed amount, press end, open door and microwave keeps going like door is closed. Is this a malfunction that requires a recall? Sharp Carosel
Hi - I'm not sure about a recall but certainly not safe to use as you have exposed yourself to radiation if the oven runs with the door open.
Common sense must prevail here - there is a high possibility the door switch(s) is faulty - have it checked thoroughly by a serviceman and check with the company if there were known problems with the particular model in question.
I find it extremely rare for something like you have experienced to occur - have never come across this problem ever - the microwave circuits are meticulously designed to have three door switches to eliminate the very problem described by you.
A but concerned...
Jul 13, 2011 | Sharp Ovens
Microwave screen says lock and I cannot get it to unlock
It depends on the oven but try cleaning around the seal for the door a lot of times just a little build up there will cause malfuntions with the key board .Make sure you look and clean under the seal you don't need to remove it . Just clean it real good and it will likely fix this problem
May 09, 2011 | Sharp Ovens
Need door seals for sharp microwave oven model R-9330A
You can probably purchase the seal from RELIABLE PARTS (1-800-663-6060 ) with the model number from the microwave
Feb 05, 2011 | Sharp Ovens
Carousel won't turn
The carousel won't turn Although the carousel is usually driven by a small motor that 'sits directly below the turntable and it has a small drive coupling attached to it .You will have to open the outside case by removingall of the screws along the back edge and the sides and the bottom then lift or slide the case towardds the back of the microwave and then lift off Now Inspect the plastic drive coupling that the tray sits on, as well as the ring-and-roller assembly, to make sure that they're working properly. and if this still looks good then replace the motor it is attached to here is a couple of picts for you fa1496e.jpg
Apr 29, 2010 | Sharp R-930 Oven
Brand new GE Profile oven/microwave combination just delivered and the carousel in the microwave will not spin.
is all the packaging removed? sometimes a tiny piece of styrofoam or tape is holding in place
Sep 03, 2009 | GE Ovens
Sharp MW won't shut off
Sounds like it needs a new electronic board or PCB. Although I would consider a new microwave as your microwave is getting on in age and can be a danger to health or dangerous if something blows up.
Jun 14, 2009 | Ovens
Inquiry on parts for ancient Frigidaire Cookmaster
Try www.monitortop,com and send email
Jan 01, 2008 | Ovens
Ovens Logo
Top Sharp Ovens Experts
Are you a Sharp Oven Expert? Answer questions, earn points and help others
