Question about Viking Refrigerators
When ice maker is filling ice cube tray it drips water only on left side which creates a frozen solid hugh ice mountain and then cant open ice drawer
Viking side by side refrigerator freezer model vcsb42355
3 Suggested Answers
ryanmalin
  • 40 Answers
SOURCE: cannot open bottom freezer drawer. Ice in tray
remove all food from fridge and take it outside. leave it outside until ice is melted. this is the procedure and i have to do it every day im a Refrigeration Mechanic.
Posted on Oct 10, 2009
baraquielnar
  • 247 Answers
SOURCE: subzero freezer, ice maker leaks water, get ice
please check the water level sensor and the inlet solinoid valve.
Posted on Mar 09, 2011
Help! Our ice cubes are frozen but not dumping and our tray is filling up with water fitting a solid sheet of ice. Can anyone help? Thanks
Hello;
My name is Peter. I am a retired field refrigeration technician.
It sounds like your ice maker has a bad motor module/circuit board.
It is like a control board. This module reads a temperature sensor that indicates the water is frozen and ready for harvesting the ice cubes. Then it turns on a electric heater under the ice cube mold, then turns on the motor to harvest the ice cubes. After the ice cubes are harvested, it opens the water supply solenoid valve to fill the mold with water. The ice maker needs to be replaced.
Feb 27, 2016 | Liebherr Refrigerators
Frozen solid cube tray
Unplug the frig. Take a hair dryer and melt the ice tray. Then get a paper towel and soak up the left over water. hope this helped
Mar 30, 2010 | Refrigerators
The Ice maker does not make cubes.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Feb 06, 2010 | Refrigerators
Cannot open bottom freezer drawer. Ice in tray
Oct 09, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
My ice maker has quit working. The water is not filling the tray.
Pour 1/2 cup of water into icemaker . If it dumps the cubes when frozen , then check the fill tube going into the icemaker , to see if it is frozen solid . If it is , remove and clean and replace water valve ( drip seeping ) . If not frozen , replace the wqter valve anyway . If the icemaker doesn't dump the cubes , and holds the frozen ice , replace the icemaker , after making sure the coils under fridge are free of dust , lint , pet hair etc.The icemaker needs to be 5 degrees to operate , and , dirty coils could bring the temp up to 6 or higher in the freezer section .
Aug 27, 2009 | Whirlpool Refrigerators
Lg side by side Ice maker not filling all of the tray/dripping
You may have a restriction in the icemaker.  Remove the icemaker and make sure that there is no ice buildup other than in the cube slots.  Also make sure that the fill tube is clear of any ice obstruction.
Mar 21, 2008 | LG LRSC-26922 Side by Side Refrigerator
Sub zero 532 ice maker
When my repair tech came out, he showed me that the fill tube sometimes retracts toward the rear of the freezer. He simply pulled it forward with a pair of needle nose pliers until it rested in the delivery reservoir. This placement allows the detector to know when the tray is full and shut off; thus not overfilling the freezing tray and/or splashing additional water onto the freezer wall and into the ice cube drawer.
Nov 21, 2007 | Sub-Zero 632 / S
My ice freezes together!
Do you mean the ice cubes are too large to be individual cubes and come out as a lump? The water is filled by a timed fill so if the fill solenoid stays open a little and drips water into the cube tray it will have more water than normal. I guess I'm not sure if you mean the ice cubes are stuck together in the tray or are they sticking together in the holding bin area?
Jan 30, 2007 | Kenmore 74172 / 74174 / 74179 Top Freezer...
The water continues to drip after the ice cube maker is full.
Sounds like the water fill solenoid valve is leaking by. You will have to change that solenoid valve if the water continues to drip into the ice maker tray after a normal fill cycle. http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=JCD2295HES&mfgModelNum=JCD2295HES&fkMfgID=1
Dec 05, 2006 | Jenn-Air JCD2295HES Side by Side...
Refrigerators Logo
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
