Question about ATOMIC Watches
Cannot adjust time on ohe atomic clock
It is almost exactly 4 hours ahead. Help!
    Habit-Forming:
  • 146 Answers
Let it adjust itself, usually at next transmission time WWV in Hawaii reset several times a day every four hours or so.Thats my experience.
Posted on May 13, 2017
Silicon scientific atomic watch
Should be 4 buttons, 2 on left and 2 on right. Press bottom left 3 times and hour offset digit will be displayed. Press and hold top left until hour offset digit starts to flash. Press either top or bottom right to adjust offset hour to correspond with your time zone. Eastern -5, central -6, mountain -7, pacific -8. These are negative numbers, not positive. Then press top left button once, then press bottom left button to return to time display.
Jul 31, 2016 | ATOMIC Watches
Clock is 2 hours ahead of actual cst time
If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
May 06, 2011 | Watches
I have a Westclox, Calander Model 70026. I have set the clock several times to the correct time,(with the time zone at the proper setting) but, after a day or so, the hour reading, reverts back...
It's most likely because of Daylight Saving Time. Your clock receives a signal through the air once a day from the actual atomic clock, much like a cell phone receives the time from your cell phone service provider, and it automatically resets itself to the exact time each time it receives this signal. Remember that the middle of the year (the second Sunday in March until the first Sunday in November in the US) is Daylight Saving Time for much of the United States. The clock has an option that allows you to set whether you are observing Daylight Saving Time or not. If this is set to "off", the time will be one hour behind until Daylight Saving Time ends (November 7th). Make sure this is set properly, and your problem will be solved.
Sep 27, 2010 | Watches
How can i adjust the date on my casio waveceptor wvq-550 watch
http://waveceptor.casio.com/support/manual/ is the link for the official manual, but I thought this one just updated to the atomic clock? it's supposed to connect every 4 hours and update itself.
Jun 16, 2010 | Casio Executive Wave WVQ550DA 1AV Watch
I have a forestville wall clock with the pull down weights. when it chimes it is behind in time. example nine oclock chimes seven oclock, it is a made in germany clock but what year i do not know. there...
Stop the pendulum of the clock exactly at any even hour. Lets say at 6.00. While clock is steady and not working, pull off the minute and hour hands off the pinion, but do not brake them. You have to pull without any twisting action. This will leave pinions exactly in place they were when you stopped the clock. When it is done - push the hour hand back onto the pinion and make sure it is pointing at 4 (not 6, as it was when you stopped the clock). When hour hand is back in place and pointing at 4, push back minute hand as it was when you pulled it off - pointing at 12. Make sure hands will not catch when passing each other (you can bend them slightly if needed). Now swing pendulum to start the clock and adjust time (clockwise only). Never adjust time when clock is chiming. Rate me, plz.
Feb 02, 2010 | Watches
I HAVE A CASIO 3054 WAVE CEPTOR WV-58A WATCH. It
I tried putting your module number in (3054) and was able to download the instructions.
Try the following link http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3054.pdf . This was successful in finding the manual you require.
Good luck and a happy new year.
Nov 05, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio Wave Captor Watch wont set to correct time.
You need to manually adjust or set the hands to the home position as they are not where the watch thinks they should be. This can happen when you bring your watch close to a strong magnetic field. Look in the manual to do this. Afterwards your watch should set to the correct time.
Apr 21, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Sharp Atomic Clock
I have a sharp atomic clock that once set for the exact time, after a day loses 3 hours.
Sep 02, 2008 | Watches
Can't receive atomic signal
You can get it serviced at www.casiosalesandservice.com or call them toll free 877.659.0761
Jun 03, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Watches Logo
26 people viewed this question
Top ATOMIC Watches Experts
Ansel Alberto
Ansel Alberto
Are you an ATOMIC Watch Expert? Answer questions, earn points and help others
