Question about GPS
What are the chords for No one feels my hurt the way you do by Tom T Hall
Guitar chords for "I feel like breaking up somebody's home"
https://chordify.net/chords/albert-king-breaking-up-somebodys-home-szymon4039
Mar 22, 2017 | Music
Broken pullcord . cord is missing how long should new cord be and how hard is it to replace
Just went through this pain today. Here's how I did it. Use allen wrench with T handle to remove the shroud over the carb controls and plug. Then remove about 10 screws and split the case. Use tool that comes with the unit to remove the nut holding the impeller. Behind the impeller, use torx head to get the other bolts to remove the motor. There are two other screws on the other side that hold the motor on. Drop the motor from the case carefully. It is still attached by wires to the throttle and kill switch. Note how the throttle linkage is connected because it will come apart for sure. On the one side of the housing you are looking at the plastic cord spool with the spring unit behind it. My chord simply pulled out of the spool. It was held on with a 10mm nut and start washer (not a good design). If the chord broke, remove the remnant from the take up spool. To rewind the new chord or replace the one that pulled free, you need to wind the spring to put tension on it. Make sure the take up spool engages with the spring tang otherwise it will turn free and not tense the sprint. Once engaged with the tang, the spool should set to the bottom to be level with the metal chord guide. Turn the spool clockwise 3-4 turns until you feel it tighten. With a 2nd pair of hands, hold the tension on the spool and tread in your chord. Route the chord through the take up reel into the hole on the side. Loosen the 10mm nut with the star washer and route the end of the chord through it. Tie a simple knot in the end to prevent it from pulling through. Tighten the 10mm nut which clamps on the chord. Now, slowly, let the spring tension take up the loose chord until fully retracted. Make sure the metal chord guide fits in the slot to channel the chord properly into the take up reel. Hold the spool down and give the chord a gentle test or two. The chord should retract easily and fully. Simple as pie!!! Reverse the disassembly and you are back in business.
Apr 01, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
What is my love
Your love? This would be your feelings for those who have cared for you. In return you care for them. But true love, comes from the the ones and only them, that hurt you. Only those that you love can hurt you (us). For a friend or family only can hurt us. If we have a deep respect for them that earned it by their care or their returned love, loss of that that respect hurts. It comes from the feeling of pain when turned on. Those only will we feel any pain, when they have wronged us, only those closest to us can hurt (us). And will get hurt by us. Pain and hurt feelings, now that's love. That's being alive. Knowing when they do something wrong to us, we feel the anger, the pain, the hurt of love. An enemy can not hurt us with wrongs, we expect that, they can not hurt us with words, we expect that. They can hurt or body's with their fist, their kicks to the gut, we get over that. But a loved one and the deepest of our love, hurts when they wrong us or call us names. So, what is your love, it rest in a hurt feeling for a person that just said the wrong thing, forgot the right thing, let you down when you needed it, left you, abused you, mentally kicked you. Or your T.V. just broke and you want to watch that new show. Now that's your love. T.V.
Oct 17, 2010 | Computers & Internet
My Tom Tom XL 325 wont hold a charge while left off
Hi, leaving the unit in the cradle exposed to the sun during hot days has been known to fry the battery causing loss of battery capacity. perhaps this could be your problem. I replaced the battery in my last GPS 4 times because of this before I analysed the problem. This will most likely be outlined in your user manual too. You might also compare the output capabilities between your blackberry and tomtom charger - it is entirely possible that you are starving the unit of a decent charge if the blackberry charger is not to the same current capacity as the tomtom charger.
Mar 19, 2010 | Tomtom One XL GPS Receiver
How to install external antenna on gps tom tom 700
i found a usb cable that plugs in to my lighter can i use this to charge my gps go 700 thrugh the usb port or will it hurt my gps system
Nov 22, 2009 | Tomtom GO 700 GPS Receiver
Tom tom gps adhesive plate
Use an 'alcowipe' available from your local chemist.
The alcohol in the wipe will disolve the glue and will not affect your windscreen.
Aternatively get a bottle of 'Spirit Alcohol', also available from the chemists and use a cloth to dissolve the glue
Feb 25, 2009 | Tomtom XL 330 Car GPS Receiver
Tom tom not turning on
yes you are better off charging the device before you turn it on
uh but it wouldnt seem to hurt it if you dont
take it back to the shop you got it from and they should give you a soultion or another unit.
cheers
Jul 19, 2008 | GPS
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
