Question about Epson Office Equipment & Supplies
How do I connect my Epson sx200 printer to my wireless network
tigertail
  • 163 Answers
SOURCE: epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Posted on Apr 02, 2009
websnail
  • 419 Answers
SOURCE: Epson SX200 refuses to recognise compatible cartridges
Hi Howard,
Bottom line, if the printer doesn't accept them, then they are not compatible... I'd recommend returning them for a refund and find a supplier that has tried and tested cartridges.
I'd love to be able to recommend a supplier but as I don't have an SX200 I can't... Others might be able to help if you can indicate where you are in the world as the SX200 is, I believe, zone specific.
Best of luck
Posted on May 06, 2009
  • 442 Answers
SOURCE: Have epson TX600FW printer, lost setup disk. want 2 conect wirele
You can download the driver for free from the link below.
http://www.epson.com.ph/epson/drivers/driver_download.htm?dc=1&mode=3&m=false&catid=4&pid=1401
Also remember to burn it to a disk for future use
Posted on Jul 20, 2009
  • 30 Answers
SOURCE: Epson Ink Problem on sx200 printer
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
takio-28
Posted on Sep 04, 2009
SOURCE: the printer won't connect to my wireless network
I had the same problem. The issue was that the printer only accepts upper case letters for the network security pass phrase. However, my password was entered in lower case during the router set up.
I had to change the network password to upper case.
Posted on Jul 16, 2010
SX200 WILL NOT RECOGNISE NON STD INKS
Check your update settings in the printer software. Turn off any automatic updates from Epson. To get updates, put some old Epson cartridges, good or bad, in while you update. Epson will log on to your printer and kill your non-Epson cartridges during auto updates.
Apr 09, 2015 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Epson sx510w prints using a cable but can't get it to print wireless
The specs for your model Epson allows you to connect the you network by wireless and by LAN cable.
The specs are as follows :-
Wi-Fi Wireless LAN IEEE 802.11b/g – compatible with 802.11n*
*Transmission rate will be limited to 802.11g and will operate in the 2.4 GHz frequency band
Ethernet Wired LAN IEEE 802.3 (100BASE-TX, 10BASE-T)
Other PictBridge
Wireless security
WEP – 64bit
WEP – 128bit
WPA – PSK (TKIP) – compliant with WPA2
WPA – PSK (AES) – compliant with WPA2
To connect the printer by a LAN cable you need to configure the Epson for an IP address that suits your network configuration and connect the LAN cable to your wireless router/hub.
The reason why you cannot print using wireless is because the wireless configuration in the Epson is not setup with the router's wireless configuration ie. SSID WPA encryption etc.
For instructions of setting up a LAN network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
For instructions on setting up a wireless printer, the Epson wireless settings need to be configured with the router's wireless settings. Go into your router's wireless and note the SSID, and encryption settings etc and configure the Epson's wireless settings with the router's wireless settings. This will allow the Epson to connect to the wireless router. Please click on this link for instructions to secure your wireless network, configure the wireless router (if you have not already do so) and configure the wireless card in the computers and wireless printer (the instructions for configuring the wireless card in the printer is the same as for the wireless card in the computers via the printer's menu screen).
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 07, 2010 | Epson Office Equipment & Supplies
Hi Howard,
Best of luck
May 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Need manual for Epsom stylus sx200
Hello!
Have you tried www.epson.com or if no luck there try my favourite site www.cnet.com if it isn't there there will be a link, Cnet's never failed me.
Press the blue button if satisfied with my Free effort, Thank You!
Paul 'W' U.K.
Feb 05, 2009 | Epson Stylus Multifunction Inkjet Printer/...
29 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
