Question about Canon Office Equipment & Supplies
My canon ir 2870 sowing error E000110-0001 what is this
    Master:
  • Canon Master
  • 563 Answers
Hi. That error indicates there is a problem with the laser unit . Maybe is dirty or damaged
Posted on May 16, 2017
Cogz
  • 1326 Answers
SOURCE: Trouble with my canon copier ir 2870
E000602-0113 means that the hard drive is having problems booting up. You may try to remove the boot chip and clean the contacts with rubbing alcahol and reinstall it and turn the copier back on. Most likely you will need to replace the hard drive or try to re-flash the hard drive.
Posted on Mar 16, 2008
KyoDoc
  • 38 Answers
SOURCE: IR 2870
The waste toner container is full. the front cover of the machine (the one with the Canon logo on it) must be removed. behind you will see a big white plastic bottle. Remove the bottle, empty the contents into the bin, wipe it off, and refit all removed parts. Finally restart the copier.
Posted on Sep 24, 2008
canontech
  • 1219 Answers
SOURCE: error code 19
You have waste toner full!
Remove the drum, on top of drum there is cork, remove cork and vacume all the waste toner out.
Posted on Jun 02, 2010
canontech
  • 1219 Answers
SOURCE: I have a caono IR
You need to replace fixing film.
Posted on Dec 28, 2010
SOURCE: canin ir 2870 error code,
FIRST TRY TO CLEAR ERROR BY GOING IN SERVICE MODE.
IF ERROR IS COMING AGAIN CHECK THE HEATER FILAMENT,THERMAL FUSE FOR OPEN CIRCUIT.
Posted on Jul 19, 2011
How to Clear Error- 000716-0010 in Canon IR2870 Copier?
E716 - There is an error in the communication with the pedestal.
After the presence of a pedestal has been detected, the communication fails to be normal for 5 sec.
1. Check the cable. Replace the DC controller
2. PCB. Replace the pedestal drive PCB.
http://www.smoothprinterservice.com/
Sep 22, 2014 | Canon Ink Cartridge GPR15 for iR 2270, iR...
How do I solve Error Code - E000716-0010 In Canon IR2870
Failure of the communication with the 2-way unit
Description
When the communication with the 2-way unit is faulty after detecting the connection with the finisher.
Remedy
1.Install the 2-way unit.
2.Check the cable.
3.Replace the DC Controller PCB (PCB4).
4.Replace the 2-way unit driver PCB.
E000225 0001
Oh, it looks like your ImageRunner's fixer unit (the heater thermistor it uses to regulate temperature) burned out or disconnected on you. http://canon-ir-6000.blogspot.com/2009/02/e000-main-cause-main-thermistor-th1-has.html
Find that little sensor leading up to the coils and replace it.
Otherwise, say that again in just Hindi?
Aug 04, 2014 | Canon Crtdg, gpr15, ir 2270/2870, bk
E000716-0010
The error you are giving isn't a toner error. It relates to a loss of communication with the pedestal. Canon's service manual says to check the cable leading down to the pedestal. If still properly seated, replace the DC Controller Board or Pedestal Control Board.
Reference: Canon Service Manual Page 694. You may be able to locate the manual by a Google search. Search for "Canon iR4570/3570, 2870/2270 Series Service Manual"
Dec 08, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
2870 canon copier machine showing error code E000024-0001
remove your doveloper unit and check sensor, it is luse or re fix again ,........
Sep 24, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Canon 2870 copier showing error E000024-0001
open your developer unit and check sensor , refix it an close unit see........your problm solved
Canon ir 2870 digital copier showing Error E000024-0001
plz clean ur developer unit dont adds toner .dyerect clen and replace it
Sep 24, 2013 | Canon imageRUNNER 2870 Copier
May canon ir 2870 eror code below E000732-0010
sir ihave ir 2870 mashine . the machine giving E000225 -001 error code
Oct 25, 2012 | Canon imageRUNNER 2870 Copier
43 people viewed this question
old marine
old marine
