Question about Tablets & eReaders
I have a kindle fire which I now cannot connect to my Wi fi hub.
rcw1962
  • 2571 Answers
SOURCE: my wi fi is not connected. How do I do that/
I picked 1 up for the first time and connected in 2 minutes.
In settings page where you add a wireless connection, you will need to know..
Security type, mine was wpa2 ( may be wpa/wpa2/wep)
SSID, your network name that is transmitted, mine was default
password, whatever the wireless password you chose with wpa, if you have wep, it gives you a pass key, you will need to log onto your router to get this
Posted on Jul 17, 2010
  • 3278 Answers
SOURCE: how does one turn on
Hello.
Sorry, but the Kindle 2 lacks a backlight function according to all reviews found on the subject.
Hope this helps.
Posted on Dec 21, 2010
  • 457 Answers
SOURCE: I'm trying to connect my Kindle 3 to my wireless
Four reasons come to mind that may prevent you from connecting:
  1. Wi-Fi Passwords are case sensitive. Please check again if you entered the password with proper casing and you did not put any extra white space in front or behind. I know, this sounds annoying, but it is really the most common cause for connection problems.
  2. Give your network a unique SSID. This is the network name that shows up in the list of detected networks. Default names like LINKSYS can be troublesome if a neighbor one block down the street happens to have a router from the same company.
  3. Some routers have a MAC address filter as a security measure, limiting service to devices specifically whitelisted. If your router is set up for this, add your Kindle's MAC address to the list of permitted devices. See your router's configuration under Wireless > Wireless MAC Filter. You can check the MAC of your Kindle from its settings page (press HOME, MENU, select SETTINGS, see paragraph headlined "Device Info".
  4. There are twelve different standards for Wi-Fi transmission collected under the hood IEEE 802.11. The four most dominant transmission modes are called a, b, g and n. They differ in radio frequency, modulation method and data rate. Kindle supports the two standards IEEE 802.11 b and g only, which is not really a problem because all wireless routers I ever encountered support one or both of these, too. However, the Linksys N-series can be set up to use 802.11n exclusively, not allowing for b or g connections. In the router menu Wireless > Basic Wireless Settings (Manual Setup), make sure the network mode is configured as "Mixed".
Please add a comment to this solution if one of these items resolved your problem. If you suffered from a different issue I did not think of, it would be nice to drop me a line, too. Other people will benefit from any experience you made.
Posted on Jan 15, 2011
  • 51 Answers
SOURCE: My kindle wi-fi is not working. I went to turn it
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
Posted on Mar 01, 2011
  • 51 Answers
SOURCE: Kindle 3 wi-fi - no response when switched on -
If the 15 second reset does not work, I would suggest contacting amazon. They can connect to your device and see if there is something wrong with your actual kindle. If there is something wrong they are usually pretty good about replacing broken kindled :)
Posted on Mar 02, 2011
My kindle won't access the WI-Fi
Go to settings and turn on wifi access.
Oct 08, 2016 | Amazon Kindle Fire HD
I'm having trouble connecting my new Kindle to my wi-fi
trouble connecting my new Kindle to my wi-fi Mary, Check the attached links,instruction and guides to get kindle connected, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Can Connect Kindle 5th Generation to Wi Fi
Fix Kindle HD WIFI problem EASY
kindle won connect with wi fi
12 major Kindle Fire problems and how to fix them
Aug 03, 2016 | Amazon Kindle Paperwhite
Why doesn't my Kindle Fire 6 recgonize my password?
Amazon.com: Customer Discussions: Kindle Fire won't accept my wi ...
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Nov 16, 2011 - My Kindle Fire recognizes the signal but will not accept my password. I have consulted ..... In reply to an earlier post on Feb 6, 2012 7:32:42 PM PST ... I tried it and the Kindle still doesn't connect with my password. I was on the ... kindle won't connect with wi-fi
May 7, 2012
Help I forgot my password
Apr 11, 2012
Kindle Fire won't recognize wi-fi?
Jan 3, 2012
kindle doesn't recognize Amazon ...
Dec 25, 2011
More results from www.amazon.com
Dec 25, 2015 | Amazon Kindle Fire HD 6 Tablet - 16GB
No longer will connect with WIFI although all other electronics are on the WIFI
Amazon.com: Customer Discussions: kindle won't connect with wi-fi
Amazon.com, Inc.May 7, 2012 - If it will connect there, then the issue is not your Kindle but the network..... I just received a Kindle Fire HD as a gift and was able to connect to the ... It used to say "obtaining IP address" but it no longer says that, so I know there ... My Kindle will not stay ...
Oct 24, 2013
Kindle Fire HD 7" WiFi Not working
May 28, 2013
kindle fire hd connects to wifi ...
Jan 5, 2013
New Fire HD drops wifi!
Sep 19, 2012
Amazon.com Help: Can't Connect to Wi-Fi
Dec 20, 2015 | Amazon Kindle Fire HD
How to tune in kindle to wi fi?
From the Home screen, press the Menu button.
Select Settings, and then select view next to Wi-Fi Settings.
In the list of detected networks, choose a network to connect to it.
If your Wi-Fi network and router support WPS (Wi-Fi Protected Setup), your Kindle will detect it.
If you don't see your network in the list, you need to add the network manually.
If the network is protected by a password or WPS (Wi-Fi Protected Setup), enter the password and then select Submit.If you don't know the Wi-Fi network password, contact the person who set up the Wi-Fi network.After you connect to a Wi-Fi network, your Kindle automatically connects to it again whenever that network is in range. If more than one network is in range, your Kindle automatically connects to the last network used.
Aug 16, 2014 | Amazon Kindle Fire HD
Cant acess my wi fi on my kindle fire as it needs my parental password which i cant rember
Not positive but think you will have to unregister the Kindle and then re-register it. You will lose everything.
Mar 09, 2014 | Amazon Kindle Fire HD
My wireless connection is disabled how do I correct
  1. Swipe down from the top of the screen to show Quick Settings, and then tap Wireless.
  2. Verify that Airplane Mode is Off.
  3. Next to Wi-Fi, tap On.
  4. Tap a network to connect to it. If you see a lock icon, a network password is required. Enter the Wi-Fi network password, and then tap Connect.Note: If you don't know the password, check with the person who set up the network. This password is not your Amazon account password.
After you connect to a Wi-Fi network, your Kindle Fire automatically connects to the network again when it's in range. If more than one network is in range, your Kindle Fire automatically connects to the last network used.
[Source]
Nov 01, 2013 | Amazon Kindle Fire HD
My kindle fire HD 7 the wireless is disabled. How do I undiable it. thanx
[Source]
My kindle keeps asking for a wi-fi password for sky37606
If sky37606 is your own wi-fi service then the password is normally on a typed label stuck to the wi-fi router itself along with the SSID of the wi-fi network which should be sky37606 in confirmation you are connecting to the correct network.
If sky37606 is not your own wi-fi then you will either need to contact the owner or administrator of that network or select a different wi-fi network to connect to as described in the Kindle Support web pages for your device.
Dec 27, 2011 | Amazon Kindle Wireless Reading Device
Tablets & eReaders Logo
43 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
