Question about Samsung Televison & Video
My Samsung MAX-DA54 It don't wanna turn on and it's supply transistor it's very hot on it's mother board, so what might be it's problem?
    Top Expert:
  • Samsung Master
  • 75,157 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size..
Posted on May 13, 2017
SDZAKKMF
  • 50 Answers
SOURCE: No Power of a Compaq Presario Computer
Make sure that the power button is conected to the right prongs on the mother board. On the writing next to the prongs it should say power.
Posted on Feb 24, 2008
Ryan5443
  • 336 Answers
SOURCE: dell 8200 won't turn on - power supply is good
Have you put in a CMOS Battery? Hard drive works?Any more information that was not in your first post?
RCF
Posted on Sep 06, 2008
KMusselmann
  • 247 Answers
SOURCE: I have intel 102 GGC mother board with dual core as processor....
go to this site www.crucial.com and scan your system. It will tell you what you have and how much more can be added.
Hope this works for you
Posted on Mar 16, 2009
heavymetal77
  • 721 Answers
SOURCE: mother board problem
Go to ebay,if it's not there....you may be out of luck. Did you try gateway? I didn't look it up but they may still service that board.
Posted on Jul 16, 2009
SOURCE: i want a total msi 845e max mother board drivers
http://www.msi.com/index.php?func=proddesc&prod_no=488&maincat_no=1&cat2_no=170&cat3_no=4 I hope this gives you a better direction that you wanted to be going.
Posted on Sep 17, 2009
Behringer EP2500 drawing large current when powered up
If you are pulling the transistor that drives the final and the problem goes away, is the driver bad? Is the power supply a multi channel isolated unit? Could the channel for that side be bad?
May 18, 2013 | Behringer EUROPOWER EP2500 Amplifier
Turns on immediately turns off
check for shorted component parts at power supply board like bridge type diode and FET transistor. if those are good, disconnect the connectors that supply going to inverter board and then turn on the tv unit if the light indicator at front panel stay and 24v supply doesn't drop which mean the inverter board was the problem of suddenly turn off.
Sep 01, 2012 | Samsung LN19B650 18.5 in. HDTV LCD TV
Samsung LNS 325 1D-the screen is blue-no picture but perfect sound-what is wrong? Thanks
Hi m5720,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason is the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This is caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the B+ is good from the power supply, if the fuse, driver transistor, driver transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Thanks for using Fixya.
Jdvillanueva
Jun 04, 2011 | Samsung LN-S3251D 32 in. LCD HDTV
My Samsung flat screen tv won't turn on and it keeps clicking - it keeps trying to turn on but then starts clicking again.
There's a couple transistors on the Power Supply board that are probably bad. On mine, the solder joint was bad on the bottom side of the board that pointed me at those transistors in particular. Part number is FQPF9N50C. Also, you could get a refurb or new power supply board of ebay or send your board in for service (also on ebay).Or there's a "repair kit" you can get that contains 4 transistors and a couple caps I think. If you are an electronics junky and like soldering stuff, that would be the way to go... I just ordered the two transistors off ebay for like $6.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=320632712822
http://cgi.ebay.com/Samsung-HP-T4254-Internal-Replacement-Circuit-Board-/230575679230?pt=LH_DefaultDomain_0&hash=item35af61a6fe
http://cgi.ebay.com/REBUILD-YOUR-SAMSUNG-BN44-00161A-Power-Supply-/200513469692?pt=LH_DefaultDomain_0&hash=item2eaf88bcfc
Jan 29, 2011 | Samsung HP-T4254 42 in. Plasma Television
The tv has been shutting off shortly after it is turned on. It will stay on after a few cycles of turning it back on, or if you unplug it and then turn it back on. yesterday it was on and it shut off and...
Hi and if its not the power supply board!??
for me its look as an component have burn in the
highvoltage deflection circuit like the horizontal driver or the output transistor near the HV tranformers
or a regulator for b boost the best is maked a trouble shouting in the set by a good technician
he should find wath is the problem verry fast
that is an hour jobs max
hope that give an idea
Apr 07, 2010 | Samsung HCM4215W 42" Rear Projection...
It doesnt want to turn on i tried taking out the fuse and puting it back in it still doesnt wanna turn on
Power supply board is dead.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 08, 2010 | Samsung TX-T3093WH TV
I wanna know whats wrong with my tv when i turn
voltage regulator transistor in the power supply is weak also you have a coupling capacitor in there thast weak too and check/ replace the horizontal output transisitor
Jan 19, 2010 | Samsung DLP HL-P5663W 56" TV
Sony problem
I suspect cold solder joints on mother board and power supply or power supply starting to go . bad driver transistors.
est for tv shop is 160 t0 225
thanks doctor video
Jun 06, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Feb 23, 2008 | Computers & Internet
Televison & Video Logo
35 people viewed this question
Jerry Greenberg
Jerry Greenberg
