Question about John Deere Garden
John Deere 3320E forward and reverse pedals sticking
  • John Deere Master
  • 7,515 Answers
You just go to the link I attached I'm sure you will get the solution of your problem.
Best Manuals
Posted on May 15, 2017
My John Deere x320 forward pedal sticks
I have ran into this before. It's time consuming to fix. You have to pull the body of the mower loose and take the pedal completely apart. Clean it and grease it then put it back on, it will work fine then. They need to put grease fittings on those pedals.
Nov 28, 2016 | John Deere Garden
John deere 3320 error code 03
Err 03 Reverse Pedal. Voltage signal out-of-range or not calibrated. Machine does not drive. Contact your John Deere dealer.
Oct 14, 2015 | John Deere Garden
John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
Mar 23, 2013 | John Deere 420,1020,2010,2020,2510,2520...
John deere 3320 starts up,engine runs,pto works however will not drive.error code 01 and 12 keep showing up
Both codes are related to the forward and reverse pedals.To cycle through and clear the codes,turn the key on and then press the forward pedal to the deck within 2 seconds and release and the do the same with the reverse pedal,the code should go away unless the problem persists.If so then you need to check the wiring to the potentiometers on each pedal and also check to see if one has been moved[knocked out of range]If none of the above is the case then either the forward or the reverse solenoids could be stuck there-by letting the tractor think you started it in gear,hence no movement,these checks are not really a do-it-yourselfer type checks so you may need to seek help from Deere,hope this helps,thanks.
Feb 11, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Peg Perego John Deere tractor 12volt will only work in reverse. Will not go forward in the slow or fast speeds
check all wre connections are not dirty or loose!
lift out pedal swith to check there too!
Cheeers Rob
Aug 16, 2009 | Peg Perego John Deere Turf Tractor
Garden Logo
94 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
