Question about Cell Phones
When i have finished using an app how do u close
Black screen keeps popping up while playing words with friends
I would reset the iPad and remove running apps you don't use.
press t.he home button twice and swipe all screens up, to close running apps. After that, press both the home button and the on/of button for several seconds, till the Apple loge comes on the screen. Then wait a minute to switch the iPad on. Could solve a lot. If not, check your wireless connection.
Mar 06, 2015 | Apple iPad 32 GB WiFi Tablet PC
Take so much time to charge the battery and while usage battery discharge so early. kindly guide?
I charge my iPad during the night so that it's ready for me in the morning.
With regard to discharge times, this is dependent on the number of Apps you have open and what other service you have running.
When you have finished with an App, press the home button twice and close each of the Apps by swiping upward on the screen. This will close the App completely, until you are ready to use it again.
Also check that Bluetooth is off when you are not using it.(go to Settings - you will find the Bluetooth switch there)
Feb 23, 2015 | Apple iPad (16 GB) WiFi Tablet PC
The HDMI connection to my TV is disconnected anytime a video finishes or the window is closed in full screen mode.
Sounds like You do not have the Current Drivers loaded for you're video card, Check with Manufacturers website. Is it AMD or Nvidia Graphics?
Both have a advanced video config Options for connecting to larger displays.If You're s does not have the Advanced Options then You're on board Video card is not capable of connecting properly and is working overtime to compensate through default procedures in Windows, Which If you're laptop does not have a fan to keep the SYSTEM cool You will end up with Damage to you're laptop
Dec 31, 2014 | Toshiba REGZA 37E200U 37" LCD TV
How do i get my apps to finish downloading i have a good wifi connection
It's not uncommon for downloads to appear to get stuck or not finish yet with a hard reboot many will often show up. The problem is with many downloads they seem to have a hard time closing either the download program or closing and rebooting the hardware.
Nov 22, 2013 | Barnes & Noble Nook HD
I have a problem with my ipod touch
Try closing other apps when using your games and whatnot. The games and such are crashing because there isn't enough memory to handle it all.
Jul 31, 2012 | Apple Ipod Touch 4th Generation
Hi there. i have a htc which keeps freezing.
You can try a few things. Firstly remove the back cover and the battery. Next slide out the SIM card and give it a wipe with a cloth to remove any static. Reassemble the phone and turn on.
Next try uninstalling all the apps that you do not need or use to free up space. Also move as many as you can to the SD card.
Thirdly I would recommend an app called "Advanced Task Killer" from the android market. You can use this to close any or all apps that you have finished using, thereby freeing up the phone's processor.
If the problem still persists, I would recommend taking it back to the vendor as it may be a hardware issue that would need to be professionally fixed.
I hope this helps!
Mar 06, 2011 | HTC Desire Cell Phone
Browser continues to run on its own and causes incoming phone calls to go straight to voicemail or show that I am unavailable
My first recommendation is to reset the phone to the "DEFAULT SETTINGS" and get the "ADVANCE TASK KILLER" ,is a free android application,that help you to close any app running on the background,that way you save battery life and memory use.Everytime you jump from one app to another on your phone,that app that you left behind still open in the background,is like the computer when you have to many page open,your computer start slowing down the speed and start freezing,Thae same happen to your phone.
Run this app everytime you finish playing with your phone and you will see the difference.
Good Luck!!!
Feb 24, 2011 | Motorola Mobility i1 Smartphone
My phone is deleting all my calls and text messages, I was wondering how I would fix that because I tried making more memory on my phone by deleting stuff but that didnt work. I also tried updating the...
my pearl used to do this all the time - only reason this happens is because you are running the old software - havent found this issue with my replacement - and because youre not closing your apps when you use them - if you keep your apps open and then just switch to phone or a diff app - it uses your memory and deletes your txts and your call log, but not your emails....... to work with this, close every app, and in the future close every app when your finished using it......
and at least a few times a week take the battery out and put it back in, this resets the memory.....
good luck
Jun 30, 2009 | RIM BlackBerry Pearl 8100
That is the same thing that has happened to me.
Try a restart on the touch, hold down menu and home button until the 'off' slider comes on. Turn it off, then on. When it comes back open the app store, install an app (just any free one) and open the new app when finished. Close the app, then try Safari. This clears memory and also works if your apps are closing straight away.
Jun 23, 2009 | Apple iPod touch
Cell Phones Logo
41 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
