Question about Refrigerators
Cant get freezer door to close as its hitting drawers
Took drawers out to clean freezer when i tried to put back top two drawers wont let door shut hot point ffa75 DOOR SEALS TIGHT WITHOUT DRAWERS IN
5 Suggested Answers
  • 67 Answers
SOURCE: freezer door not sealing
replace the seals and / or have the hinge adjusted
Posted on May 01, 2009
  • 13 Answers
SOURCE: The refrigerator door does not close with a tight
adjust doors on the top of machine the hinges move to adjust and leval them. hope this helps
Posted on Jun 06, 2009
  • 234 Answers
SOURCE: Hotpoint FFA75 Fridge Frezzer. Freezer door not
This could indicate that your defrost cycle system is nor working and frost(ice) is building-up on the cold coil in the back of the freezer compartment. This will definitely expand the back plate and the drawers wont go in completely. You need to have the defrost system checked: either the timer, the defrodt coil, or the defrost thermostat. Goodluck, Macgivor
Posted on Jan 02, 2010
  • 48371 Answers
SOURCE: Our bottom freezer door wont close on our samsung fridge. When we remove the top drawer from the freezer, then the door easily slides shut, but if we put the top freezer drawer back in it wont shut.
check for a build of ice at the back of the top draw
Posted on Dec 14, 2015
Fisher and Paykel dishwasher Two drawers. Took top drawer out to fix leaking problem When put back together, closed the door and it is seized shut.
These use a claw type catch that rotates on a fixed loop catch receiver. Try removing the dishwasher lid, and remove the catch receiver to allow the door to open, With care you can then free the catch, and it will need to be adjusted correctly to prevent over rotation again. In the worst case, you may need to remove the inner door panel to free the door catch / receiver.
Feb 02, 2018 | Fisher and Paykel Dishwashers
Cant put drawer back in beko freezer
Drawers usually have stops to prevent them from being removed completely in normal use. You may have to experiment with the empty drawer to find a way to slide it over the stops into the closed position, then slide it open to load it.
Jun 03, 2016 | Beko Refrigerators
The freezer has a white plastic back panel with vents to blow the cold air into drawers. That thing pulled away (ice formed behind it) - how to put it back?
there is some ice that has frozen the door in a fixed potion, if you have hair dry put on warm point toward where it hinges other than that call some service person to help you.
you mite call the manufacture customer service dept. ask for service
technician, explain whats wrong and see what they say. it never a bad question, or to ask for help!!
Oct 06, 2015 | Refrigerators
I just bought a house with a Kenmore stainless steel bottom drawer freezer. The freezer drawer does not close completely and large amounts of snow and ice accumulate inside. I have taken the drawer out,...
Check top see if the arms of the drawer are fully seated into the rails which support it and extend from inside the freezer when the drawer is opened. On most french door refrig's, there are hooks on the back side and tabs on the front side which are sometimes hard to get back in. Then the door is locked into the rail with a screw at the point where the rail meets the freezer door.
Aug 21, 2010 | Kenmore 73503 Stainless Steel Bottom...
We have the bottom drawer freezer, top french doors, 3 months old, freezer will not shut all the way and now after door open beep has gone off for an hour the whole unit has gone dark
Make sure nothing has fallen behind the freezer drawer or is hitting the top of the freezer to prevent it from closing. Also check that the tilt open front is in the closed position. If nothing is blocking the drawer the gear wheels that support it may not be in the right position. See Owners Manual for instructions about removing/reinstalling the drawer. When you get the drawer to close you may have to unplug the power cord for 30+ seconds to get the unit to reset and restart.
Aug 11, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
I have a side by side Viking refrigerator and after leaving the door open a little too long the lights went out in both the refrigerator and freezer. I figured that they would go back on automaticlly after...
Remove the center grill of the top grill and shut the power off and back on, the lights should reset
When the lights are working open the Ref door then close the freezer drawer, watching to see if the light in the freezer shuts off. It should shut off when the freezer is about 1" from closing. If it stays on until the door is fully closed then there is a problem with the light switch in the freezer.
Normally when you leave the doors open until the lights shut off, it should reset when both doors are closed
Mar 06, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
Bottom drawer does not properly close
Okay, I fixed it for now. The design for this bottom freezer drawer is not good. What happened was most likely that my son slammed the door, and it bounced and was slightly open. Overnight, ice started to form all over the compartment, including inside the drawer guides. Some ice was probably obstructing the drawer glide from sliding shut.
What I did, not thinking this was the solution, was to prop chairs against the drawer to close it while I searched for answers on the Internet. In the meantime, some of this ice must have refrozen in the closed position (due to the weight of the chairs). When I went to check it later, I had a little trouble opening the drawer. I gave it a hard yank and some small frost flew off, as I opened the drawer.
It was not easy sliding it due to the frost. I then moved it out and in until it felt smooth, and finally closed the drawer and it stayed in the shut position.
Kids are instructed to close the drawer gently and visually check that it is sealed. There is also an air passage between the refrigerator unit and the freezer so that when you close the double french doors, some air pushed to the freezer section and momentarily pops the drawer open. You should make sure that the drawer closes before leaving the kitchen. If you are on vacation, prop chairs to make sure both the freezer drawer and the french doors stay closed. This is important if you're in an earthquake area as a small tremor could open the doors and you'll get a fire when the lights stay on and burn through the wiring (as others have noted).
Dec 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
My FFa70 hotpoint freezer will not close unless i take out all the drawers. What is the problem?
there is something wrong with the drawers position. they could have been installed in the reverse position or they could have been in the wrong placement. one could be on top while the other could be at the middle.
try putting the drawers one by one and check each time if the door could be close by then.
tnx 4 using fixya,
Oct 14, 2008 | Refrigerators
Kemore model 795.7731 bottom freezer
You are probably correct that it is the evap motor. If you are seeing frost on the back wall then there is probably some ice built up around the motor and the fan blade is hitting it.
Try defrosting the freezer and look very closely all around the seal for the freezer drawer. It is common for moisture to freeze in the self closers in the drawer rails and not let the drawer close completely on one side or the other. If this happens the small gap will allow the freezer to frost excessively.
Sorrry to be slow in responding. I have been very busy this week and have not been on line very much.
Apr 10, 2008 | Refrigerators
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
