Question about Bosch Washing Machines
Bosch exxcel 7 wae24467.f.17 keeps appearing and shuts off washing cycle have to restart and then generally ok. water supply is ok i have checked this. so what is wrong?
barkencoa
  • 3463 Answers
SOURCE: fabric conditioner drawer does not empty
The inlet to the conditioner compartment is probably blocked.
Get a thin piece of flexible wire and make a right angled bend on the end about 1" long, and poke it into all the holes u can see in the top of the dispenser compartment, particularly the ones at the front right side.
This should solve the prob.
Plz rate this solution .
Thanks
Posted on Jan 02, 2009
ginko
  • 19396 Answers
SOURCE: my bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Posted on Feb 07, 2009
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
Posted on Sep 13, 2009
jonniewalker
  • 1031 Answers
SOURCE: f04 error message on a bosch exxcel 1400 washing
This error indicates an obstruction in the water pump. . Tip machine back so you can fit a bowl under the bottom right hand side. Flip back cover at bottom right to reveal pump filter access - unscrew (quite a bit of water comes out so have the bowl ready).
Posted on Sep 26, 2009
Daniel S
  • 4323 Answers
SOURCE: I have F63 flashing on Bosch exxcel 7 washing
Hi
Error F 63 means Functional safety error. It appears when processor has broken SAFETY ERROR. To reset this error you'll have to switch ON/OFF the washer to reset the error. If the issue persists then check whether washing program is halted or aborted, if the washer doesn't advances to next cycle then you
Posted on Nov 27, 2010
Does the Bosch Exxcel 7 1200 Express have a child lock function?
try the manufactures website for free manual download
Dec 08, 2013 | Bosch Washing Machines
Bosch washing machine fills with water throughout any cycle
Just a guess but could the fill valve be defective, not shutting off completely when it should?
Nov 21, 2013 | Bosch Washing Machines
Bosch Exxcel 7 1200S Express error code f:21, unable to unlock door
Check for water still in the drum if so just clean filter and restart if no water in drum you may have to replace the door interlock
Oct 28, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Bosch Exxcel 1400 washing machine problem
Bosch Exxcel 1400 washing machine This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 20, 2012 | Bosch Washing Machines
The washing machine is taking longer time
You can check that pump filter which is behind the base plinth, also check that the water entering the machine is at a reasonable pressure. If the machine is taking a longer time to wash and both inlet and the outlet of water is ok, it is more than likely a wash side heater fault. Basically, you set, for example. a 40 degree cycle, the heater does not operate and the water never reaches the required temp, the machine ventually times out on the heat phase and then moves on to the rinses or aborts to the end of the cycle.
Nov 26, 2011 | Bosch Washing Machines
I have a Bosch Exxcel dishwasher which runs the drain pump constantly even with the door open and despite there being now water in the machine at the cycle wont start. I have checked the warer amtrix and...
I am not sure about this model but most models run a drain cycle for a set period at the start of a wash cycle and then move on to normal filling and cycle of machine provided the various switches are at the low level it will carry on to its set cycle,is the apartment or flood switch ok?
Jun 30, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
My bosch exxcel dishwasher will not drain after wash cycle
May 26, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
BOSCH WFF 200L
heater element may have gone, when you manually advance the settings you are skipping the heat cycle.
Jun 02, 2007 | Bosch Exxcel WFO 2465 Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
