Question about Cameras
How do I know when the batteries are fully charged in a duracell cef14uk charger
  • Cameras Master
  • 5,412 Answers
Use a battery tester - under £5 from LiDL's
Posted on May 13, 2017
Fujifilm battery fully charged but camera says no charge or very little. Just bought a new Duracell Battery and Charger for my Fuji FinePix J10 Camera. Used the charge on the battery in the camera from...
Well you mentioned that it worked fine yesterday with the battery out of the box. That should tell you that the camera and the battery are both fine. The issue is likely the charger itself. Try recharging it again, and double check that you inserted the batteries correctly, and that any switches (such as for 2 or 4 battery charge) are set in the correct position on the charger. If this doesn't work, take the charger back to the store for exchange/refund as defective.
Jun 11, 2011 | Fuji FinePix J10 Digital Camera
When I insert some batteries the red light begins blinking. I also have some Duracells that appear to be charging but when I place them in the appliance they are dead.
All chargers cannot charge all types of batteries. Are your Duracell batteries NiMH or Alkaline? These indications generally happen when you insert a battery type that is not rechargeable.
Dec 13, 2009 | Duracell AA/AAA NiMH Battery Charger with...
I charged my Duracell 2400 mAh batteries for 15 minutes, and I was able to shoot only 10 pictures with them in my digital camera before they went dead. What is the problem here? I repeated the process with...
your lucky then,,, they take 16 hourse to fully charge unless you rapid charge them? a nasty thing to do to a new battery? all ways slow charge them first,,
never fast charge any battery only charge at whats called "the C10 rate!" they live much longer that way,
in other words slow charge when first charge,,,faster after that! ok,, did you not know you must "form the cells first" before you use them?
Oct 24, 2009 | Duracell NiMH AA/AAA Battery Charger with...
My 15 min. Duracell charger keeps blinking-won't work...
When the duracell lights blink during charging, AT YOUR OWN RISK, try a reverse charge. Instead charging positive to positive and negative to negative, try positive to negative and negative to positive. I did this for 2 minutes. This solved the problem. After the 2 minutes, I gave the batteries a normal charge. You will have to force the battery and charger contacts to touch.
Jul 08, 2009 | Duracell AAA NiMH Battery Charger with 4...
Quick battery drain
No sorry to say this is normal for this camera! you may want to look for rechargable lithium batterys (they will last longer in a high drain device such as your camera!
Please rate my answer!
THANK YOU!
Jan 12, 2009 | Fuji FinePix S7000 Digital Camera
How to use
with Nimh batteries you can charge them anytime, you dont have to run them down first like nicads. just put the batteries in the charger with the flat end (-) against the spring and plug it in. some models have a red light to show its chargeing and a green one to show its fully charged while others just have a light to show it is chargeing.
Dec 19, 2008 | Duracell AAA NiMH Battery Charger with 4...
What color should LED be when charged on duracell NIMH charger
When the batteries are charged fully the light should be green.
Nov 27, 2008 | Duracell NiMH AA/AAA Battery Charger with...
Batteries require several charges in order to reach fully capacity
I wont exactly call this solved but I called duracell and they think the batteries are old. They are sending me a new set of batteries.
Sep 08, 2008 | Duracell AAA NiMH Battery Charger with 4...
Cameras Logo
48 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
