Question about The Audio Players & Recorders
How connect a tv box on the radio to listen radio via TV
    Problem Solver:
  • 9 Answers
It will depend on the radio and TV you have. If you have a radio with outputs, right (red) and left (white) female plugs next to each other on the back, you can either run that to the back of the TV (if there are audio inputs on the TV) or plug the left and right wires into an adapter with video and audio inputs/outputs used for connecting DVD players to older TVs. The cable you need is called an RCA plug which comes in many different lengths and is two wires together with red and white plugs. You can then plug the adapter to the TV with a standard cable antenna that screws into the back of the TV.
Posted on May 13, 2017
  • 3 Answers
SOURCE: Connecting the LE46A556P LCD TV to the HTZ310R Home Cinema System
You need to be connecting the TV and the Sky Plus to the HT box via optical (toslink) for full surround sound. As you only have one optical port on the HT, I would suggest buying a Optical selector such as this one. I would also suggest looking on avforums more more help. I use it for most of my questions if ever i need any help.
Hope this helps!
Posted on Jun 01, 2008
  • 3940 Answers
SOURCE: How to switch from Computer to TV if the PC is connected via D-sub and Set top box via HDMI port
Most LCD displays have an input select button to choose the TV ot PC display. You just press the button and it cycles thru the options. Normally starting with VGA, then DVI and then the remaining input options.
Posted on Jun 19, 2008
  • 3 Answers
SOURCE: listen to TV through my vsx-454
  1. Go To RADIOSHACK
  2. GO buy RCA Cables(red,white,yellow)
  3. If your Tv Has An RCA Output Connect the RCA Cables @ one End of the TV.
  4. Connect the Other End to THE VCR2 Input.
  5. SWITCH THE INPUT TO VCR2
Posted on Jun 14, 2009
  • 11800 Answers
SOURCE: how to connect virgin digital tv box so i can
Connect your box to the tv using the Composite connector (or the YUV ones if you have them on you model) and the box to the amp with the Audio L and R connectors.
Posted on Oct 27, 2009
mlapres
  • 757 Answers
SOURCE: Got a Kenwood vr405 surround receiver, a Sanyo
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Posted on Jan 14, 2010
Testimonial: "Thank you for the insight. I may have figured this out on my own eventually but this definitely got me situated much much faster. "
How do i connect marantz rs2252. To tv
Do you have an audio out or headphone jack on the TV? If not you'll need a digital TV tuner converter box that does. If you remember, these are the "digital conversion" boxes the government provided when the USA switched from analog to digital TV. They sell for $50 - $60, have a input for TV system (antenna, cable, etc) and analog outputs that will connect to your Marantz via the "Aux" input. Purchase shielded "RCA male to RCA male" connection cables at Radio Shack, connect "Audio Out" from converter box to "Aux In" on Marantz and you're done.
Mar 28, 2015 | Marantz Audio Players & Recorders
TV headset using bluetooth
THis is a function of the TV and Car Radio Models. The question in too broad to answer without those details.
Nov 10, 2013 | Radio Communications
Yamaha rx-v663. Want to watch cable tv while listening to cd (blue ray).
Don't think there is a way to make that happen with your setup
Dec 31, 2012 | Yamaha RX-V663 Receiver
I just purchased a Sony flat screen tv and need advice on what wires I need to connect my Denon AVR-3300 to it or to the dish cable box? My remote has these options on the remote to listen in...
Your reciever has three digital optical inputs so, what it comes down to is how many thing do you want to hook up and what input/otput do you have on your TV. Best case scenario would be to hook your cable box directly to your TV Via HDMI out, if you have HD, on your cable box to Sat/cable input on your TV. Next best would be using componenet cables for video and digital optical for audio. Last would be RCA(yellow, white and red, from Cable box to TV input. Then, you would connect your TV to receiver via(best) digital optical, or RCA. You can try to patch the video through the reciever using component or RCA to TV/DBS on receiver then out to TV but. alot of times you will lose the video in the transfer and it uses more cables, thus more margiin for error. You would set your TV menu to cable/sat and your reciever to which ever input you choose.
Jul 03, 2011 | Denon Audio Players & Recorders
I have a 19 " sansul cant get my ilive sound bar
I hope this helps. You have to connect your sound bar to your cable box/satellite tv receiver. If you are connecting with composite or component cables you connect the video cables (either the yellow or the green blue and red cables) between the television and the cable box /satellite tv receiver. Then you connect the red and white audio portion of the cable between the cable box/satellite tv receiver and the sound bar. You are going from the OUTPUT of the cable box/satellite tv receiver to the INPUT on the television and sound bar. You use the function/source/input button on the sound bar to choose the space you plugged the cables into on it or listen to the radio or listen to your IPOD and etc.
Jun 10, 2011 | Sansui HDLCD-1900 19 in. LCD Television
How do i connect a virgin cable box with only scart output to a sony str dh810 AV reciever?
If your TV has audio outputs of any description, connect the V box to the TV via SCART and then connect the TV's audio output to your AV amp. This will allow you to use the amp to listen to the Virgin box's output being displayed on the TV. If you want to listen to mp3, connect the MP3 playing device to the AV amp. Select this source rather than t he source being used for the TV's audio. THe video output of the V box will still be displayed on the TV while you use the amp to play audio sourced via a different input on the amp.
Feb 03, 2011 | Televison & Video
No sound through the Panasonic cinema surround sound on TV
Had a similar problem mate. I solved it by connecting the tv to the PT460 system with a scart lead. You then have to have the AV channel selected on the PT460 system to listen to the tv. You will always have to have the AV channel on the PT460 selected to listen to any sound transmitted through the tv - be it playstation/xbox or any other device that you may connect in the future with HDMI leads or otherwise. Hope this helps
Jan 04, 2009 | Panasonic Home Theater System System
Query about listening to radio stations
I created a 'favourites' list of programmes and added the radio channels. Then I could select them in the same way as I did my favourite TV programmes.
Dec 29, 2008 | Televison & Video
29 people viewed this question
Top The Audio Players & Recorders Experts
bihug
bihug
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
