How do we remove the filter from a hot point Aquarius washing machine
    New Friend:
  • 3 Answers
Try to put a washing machine in cold area
Posted on May 13, 2017
Testimonial: "Really?"
Hi washing machine Aquarius hot point wt540 lights flashing will not turn off or cancel. Removed top top find the wires had burnt .
You could cut both ends beyond the black and use a butt connecter to splice them together. Don't forget to unplug it first
Sep 29, 2012 | Washing Machines
How to get to filter on aquarius extra washing machine
Remove lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Reassemble in reverse order.
Dec 16, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Where is the filter located on a Hotpoint Aquarius WM63 washing machine?
Locate and remove the large black hose from bottom of drum, remove and clean the filter inside the hose.
Oct 21, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hi there, i got a hot point washing machine who will not drain water,need help to diy thanks for any assistance
Remove the rear lower panel of washer, locate and remove large black hose fastened to bottom of drum.
Please rate my solution.
Nov 10, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine stops mid cycle and lights start flashing
Drain the water by lowering the hose into a bucket or something and then try it on spin, if it spins o/k then you probably have blocked pump or filter.
The filter is located in the large black hose that is fastened to the bottom of the drum, remove and clean.
Hopefully this will solve the problem.
Plz rate this solution.
Dec 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hot point aquarius wf740
F03 indicates that the wash thermistor is open or short circuit.
I think you need to call engineer to sort the problem
Please leave feedback.
Dec 02, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius wf340
First remove the filter (if you can do this easily) - place a roasting pan under it to catch the water.
If you cannot get to any filter, remove the rear pipe from the waste pipe, and check it is not obstructed.
If it looks good enough, try a hot wash with 1 cup of soda crystals. This should clear any accumulation of grease in the pipes.
If still no good, you may have to open up the machine to clear any internal filter before the pump, and check pump vanes are still intact.
Nov 05, 2008 | Kenmore 13202 Top Load Washer
Washing Machine 1200 Aquarius- Hot point- will not spin?
hotpoint use two types of brush depending on the motor. if motor mounted at top of machine, brushesw are clip in and very easy to replace. look at new brush and you will see how it clips in. no need to remove motor. if motor at base of machine, brushes are screwed in with two screws per brush. rather fiddly to do in situ and you may be better of removing motor and doing job in an easy position
Apr 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
Top Washing Machines Experts
