Question about AEG Ovens
How do i get the safety lock off my aeg competence oven can,t open the door?
You can look on eBay to buy a used cooker and use it or spare parts
or if its better replace your own.
Posted on Sep 15, 2008
  • 3463 Answers
SOURCE: aeg competence oven fan not working
If fan has stopped altogether, then you definately need a new one, to be sure you need to disconnect and remove the fan and bench test it.
Hook up a 240v supply to the fan and see if it runs, if not then it is no good..
It does not matter which terminals you connect live and neutral too as it is common to both terminals. do not connect feed to earth by mistake.
Plz leave feedback.
Posted on Dec 09, 2008
  • 3463 Answers
SOURCE: AEG Competence Double Fan Oven Fault
Sounds like oven element is faulty, disconnect it and try again, if it does not trip, then it is definately the element..
It is easy to replace.
Plz leave feedback.
  • 3463 Answers
SOURCE: aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Posted on Jan 27, 2009
SOURCE: Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Posted on May 05, 2009
Aeg b5741-14 oven has code f5 -what does this mean?
Here is a list of oven error codes for your model Kenmore oven.
  1. F0 indicates a Stuck key pad.
  2. F1 and F7 may mean relay is turned on.
  3. F2 indicates that the oven is over temperature in one of the following modes within either cooking or cleaning mode of operation. The control is sensing over 615 degrees with the door lock circuit in the unlock mode. Control senses oven temperature above 915 degrees with the door in the locked mode.
  4. F3 and F4 indicates an open or shorted oven sensor or sensor circuit.
  5. F5 indicates a loss of relay drive circuit.
  6. FF indicates a loss of door motor safety switch.
  7. FC indicates a door lock circuit problem.
If the display of your control is flashing "F" followed by a number or letter its a range malfunction. Press the clear/off pad. Let the range cool for 1 hour and place the range back into operation.
If the problem repeats, call for service.
Jul 16, 2011 | AEG B5741-4 Electric Single Oven
Where is the model no on our aeg white double oven competence about 8 years old
Open the door, usually engraved within the door panel. Either on the sides or Top.
Most important number is called the PNC. If not found there, look for a sticker on the Oven Cabinet upper, after opening the door.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively.
Feb 16, 2011 | AEG Ovens
The light on my aeg competence oven and grill is not working. I can not use the timer.
It's either the thermostat / switch or the timer unit. Make sure the timer was not set to have turned off the grill first
May 20, 2010 | Ovens
The top oven of our AEG D5701-4 is slow to heat.
Hi it could be the element on the grill it maybe burning out, what slows the grill to get hot quicker. best to turn of the mains or by the main switch. and get a toorch to check around the element or use a continental reader check if it is receving 240volts
Mar 09, 2010 | AEG D5701-4 Electric Double Oven
How do you clean inside the glass on AEG Competence 51581 B
take door off using locking hinges ,then simply take doors apart,
Mar 09, 2010 | Ovens
AEG Competence Oven not working
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
Feb 05, 2010 | AEG Ovens
Timers on my aeg competence cooker
Hi, My Competence B1180-4 digital clock keeps switiching itself off and then back on. This means that the timer etc dosen't work. It is intimitant.
Aug 10, 2009 | AEG B1180-4 Electric Single Oven
I need a rubber seal for an AEG B6139-M Competence door oven
If you are in the u/k, then look in telepohone directory for Service Force, they are the service agents for AEG.
Please rate my solution.
Jul 16, 2009 | AEG Ovens
AEG COMPETENCE DOUBLE OVEN - 13 year old model
Jan 04, 2008 | Ovens
Ovens Logo
54 people viewed this question
Top AEG Ovens Experts
Sal De
Are you an AEG Oven Expert? Answer questions, earn points and help others
