Karda heat pump not working and displaying E1 on the screen
2 Suggested Answers
SOURCE: karda heat pump not working and displaying E1 on
Did you ever get a solution to this? Mine's doing this today!!! I can't find anything in the user manual to help, either.
Posted on Jul 21, 2010
I got the E1 at the display I understand that is sensor on how kan i get it of so i kan get the heat back on
This error is a high limit sensor failure. IT could be lack of water flow, check the filters, make sure all the jets are on. Check the pump impellors. IF there is nothing wrong, change the sensors on the heater manifold. There are usually two and they look like silver cylinders with wire coming out of them.
Feb 09, 2017 | Heating & Cooling
WTL 5410 getting E1 error message. Condenser hose seems unblocked. Pool of water behind the heat exchanger
Cycle is interrupted and ''E1'' appears in display.
Condensate hose is blocked in some way. Turn off dryer and check hose.
Condensed water not pumped out (WTL 54 condensation models only). Pump failed.
Dado
Jul 02, 2015 | Bosch Dryers
What wrong my comfortstar mini **** outside unit not coming on and I am getting e1 error code
I am somehow listed as someone who "solved" a Comfortstar mini problem - but I have not. And the company that installed it cannot. I am really fed up with the stupid thing.
Jun 17, 2014 | Ingram's Water and Air ComfortStar Mini...
What is a E4 code mean
Error Code:
E1 Loss of communication between the Single Zone LCD thermostat and the mod-ule board. LCD will cycle between E1 and the previous mode setting. System
will shut down.
E2 Open circuit or out of range Indoor Temperature Sensor. Heating and cooling
operation will be locked out. Fan operation can continue to operate.
E3 Shorted Indoor Temperature Sensor. Heating and cooling operation will be
E4 Open circuit or out of range Outdoor Temperature Sensor (select models). Heat
Pump operation will be locked out. Air Conditioner, Fan and Furnace operation
E5 Open circuit or out of range Freeze Sensor. Air conditioner mode of operation
will be locked out. Furnace, heat strip, heat pump and fan mode of operation can
continue to operate but displays the last temperature set-poi
Dec 18, 2012 | Dometic 3313192.000 White Single Zone LCD...
What does E1 error code on a Karda heat pump, model KSAC-18HRDCI mean as there is nothing in the manual about error codes. How do you clear it?
I have worked this out. There is a 20A fuse inside the compressor(outside) unit, it is a glass fuse that has a sleeve over it and is soldered to the PCB. They appear to have a manufacturing fault and 'blow' at a lower current than the 20A, Just the edge of the fuse link is not properly bonded to the end cap. On inspection they don't look blown, but test open circuit. Was a relatively easy fix with a soldering iron and a new 20A fuse. You can find this fuse on the gas piping end of the compressor.
Sep 12, 2011 | Heating & Cooling
E1 and E4 error code desplay on the screen induction cooker. what is the fault in the induction cooker?
E0 error - ensure pot or pan is placed correctly
E1 error - the circuit has malfunctioned
E2 error - the temperature sensor is opening circuit or short circuit
E3 error - the voltage is higher (140 - 160V) for 3 seconds
E4 error - the voltage is lower (80 - 100V) for 3 seconds
E5 error - the cooktop surface temperature is too high
E6 error - Internal electronic temperature is higher than normal for 3 seconds
E7 error - Internal electronic temperature sensor is opening circuit or short circuit
Dec 12, 2010 | Stoves Heating & Cooling
Oct 29, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
