Question about The Watches
The pendulum swings for a few minutes then stops how do i fix/
    Habit-Forming:
  • 146 Answers
If this is a true pendulum mvmnt, you must have it level and plumb. check with a level and adjust case to achieve as close to even as you can.
Posted on May 14, 2017
  • 2501 Answers
SOURCE: Bergen Enkheim Clock won't stop chiming. The
It sounds as though part of the mechanism that controls the chiming is jammed. This could be caused by dirt or wear.
I suggest you have the clock cleaned as a first step and ask if there is any sign of damage.
Posted on Jan 06, 2010
Testimonial: "Thank you very much for the advice *. ~"
cmcduncand
  • 714 Answers
SOURCE: The pendulum stopped swinging...the clock and
Hi
This clock short of needing a full service may simply be out of beat.
Taken from my web page located at:
http://antiqueclock.clockstop.com/CLOCK_BEAT.htm
"HOW TO PUT YOUR CLOCK IN BEAT"
-Included below is a 10-second sound <snip> of a clock both in and out of beat.
IN BEAT ////////\\\\ OUT OF BEAT
· Turn on your sound and click on the clocks above for a sound clip.
-One little known fact is that a clock does not have to be level to be in beat. I had a customer that had a mantel clock in an old farm house, it was brought in for repairs and sent back running great just one problem: I put the clock in beat on a level surface [a small problem] because the mantel it had set on for it's entire life was not level. I had to literally go to the house to put it in beat where it sat.
-I have often found most Grandfather or floor clocks are set up out of level and put in beat where they stand, This is fine.
-As I'm sure we now realize a clock must be in beat but not always level to function properly.
· Above is the verge with a slip clutch.
· Often found on Grandfather clocks and requires only a long swing to get it in beat.
-To get the clock on the right side in beat you would need to push the verge assembly to the left.
-If it must be bent to put it in beat, do it slightly, but don't bend any of the suspension parts.
R/ David
Posted on Jan 21, 2010
cmcduncand
  • 714 Answers
SOURCE: pendulum in beat but stops running after a few
CLOCK OILING TIPS * NOTE: Many Master Clock Smiths and Hobbyists used many different oils and as many different techniques.
* It is only good sense to use only the best in quality when selecting clock oils and grease. A number of fine oils are made especially for clocks. The oil used should stay in place and not evaporate easily and have no tendency to gum or get sticky as it ages. Most clock oils meet these standards. [CAUTION: Never consider using non-clock lubricants, as they tend to not really work well in clocks. Some are too light and cause unnecessary bushings wear, while others are too thick or can evaporate, over time will gum up and stop the clock prematurely.]
Oiling Procedures
-Main-springs are oiled after cleaning and before they are recoiled.
-Teeth and pinions are never oiled.
-Normally, the dial train of gears, hour wheel, minute wheel and minute wheel post are not oiled. However, oil is used between the center shaft and cannon pinion where slip friction is present in setting the hands.
-All points of friction such as train wheel pivots to bushings are oiled. Verge faces are oiled directly.
-Oil is always used sparingly and should never run all over the plates.
Hope this tip helps.
R/
DAvid
http://antiqueclock.clockstop.com/oil.htm
Posted on Feb 08, 2010
  • 2501 Answers
SOURCE: I have an Elgin Westminister Quartz Chime clock.
I have a clock with a pendulum and it has two batteries, one for the clock and one for the pendulum.
Perhaps your is the same?
Posted on Mar 13, 2011
aquaman987
  • 927 Answers
SOURCE: we have a seth thomas
The clock must be levelled the same as when it was previously set up. In other words, if you didn't check the level of the clock before disassembly and reassembled it and re-levelled it, it may not operate because it might not be the same.
Some clocks have different weights for the clock, chime, and hour strike. Did you mark them and install them in the same location?
My Seth Thomas has a screw to adjust the swing of the pendulum to allow proper escapement on the gear, but you have to be able to determine which way the pendulum needs to swing more to make that adjustment. I may be able to help you with this!
You may need a clock repair service.
Let me know,
Gary
Posted on May 29, 2011
How to fix the pendulum on an elgin quartz anniversary clock
I am unsure wha you mean by "fix the pendulum". If you mean it stopped swinging, there are two reasons: first check the battery and contacts. Remember, even a new battery can be bad, which is why new things come with warranties. The other thing is quartz movements usually don't last too long. If the pendulum is not swinging, and is correctly attached to the movement and the battery is good, then the movement has gone bad and you need a new one. Most all clock shops keep quartz movements on hand. If you are a do-it-yourself type, you can get them off the Internet. Be sure to remove the old one first and check how thick the dial is, that's how they sell them by dial thickness.
Oct 26, 2017 | Elgin Watches
I have an Elgin Westminister Quartz Chime clock. Everything works fine, except the pendulum does not swing, anymore. Can I fix this or can I buy parts to fix this problem?
Mar 13, 2011 | Watches
Re: Galleria / Metro Grandfather Clocck. W/ pendulum on lower hanger clock runs slow. W/ pendulum on upper hanger clock runs fast. How can I adjust so it will keep correct time, or should I take it to a...
Most grandfather/grandmother clocks have an adjustable screw on the weight to slightly extend it or shorten it to satisfy the equation of pendulum swing. the shorter the swing (arc distance) the faster the clock, the longer the swing the longer the time. Check to see if you can adjust the weight up or down on the hanger.
Jan 01, 2011 | Watches
I do not know how to start the clock : Clock under glass. Has three balls supposed to swing. I replaced the battery.
Lift the glass and swing the pendulum/balls. Or you could, if it's small enough to hold in your hand, suddenly twist it, there by using inertia to swing the pendulum.
Aug 03, 2010 | Watches
Pendulum stops within a few minutes
Spaying with oil may cause more problems than it solves, as the oil collects dust and is likely to clog the machism.
Although I have never tried it myself, I have been told that the way to clean clock mechanisms is to put some cotton wool beneath the mechanism and pour some surgical spirit onto the wool. I understand that the rising vapour lifts off the dirt.
Must be worth a try.
If this does not succeed, then take it to a watch repairer.
Good luck.
May 27, 2010 | Watches
Bakelite antique mantle clock just bought, but no instructions of how to get it going. Ive got the key and pendulum but dont know how to set it up. Can you help?
First you have to wind up your clock using the key supplied. The pendulum suspension spring should start to swing quite fast. Stop it swinging with your fingers and hook up the pendulum. When done, push the pendulum to whatever side and release it to start the swing - the clock should start ticking in normal order. If there is no special bar on the back of clock movement for adjusting hands, then hands must be adjusted from the dial side by moving minute hand clockwise. Move the minute hand with your finger clockwise to the desired time, at the same time do not catch hour hand, as this may end up with the incorrect time displayed. Rate me, plz.
Jan 28, 2010 | Watches
What ports wind what?
On mine, the center one (@the 6 position) is the one that keeps the pendulum swinging. It is the one that lengthens the most during the week and if I forget to wind it, that pendulum is all the way down when the clock stops.
May 02, 2009 | Watches
Seiko kinetic
I habe seiko kinetic work and stop work
Feb 07, 2008 | Watches
Watches Logo
26 people viewed this question
Top The Watches Experts
John mullen
D. E. Hev
 En Sukkert
En Sukkert
Level 1 Expert
Are you a The Watch Expert? Answer questions, earn points and help others
