SOURCE: It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
SOURCE: Reddy Heater keeps shutting down
I tried to go to www.desatech.com and you cannot buy parts on that site anymore. I can get my Reddy Heater parts at www.masterparts.net.
SOURCE: 3 beeps and lights flash when I push the start button
The door is not compltely closing. Make sure to push it in hard around the clasp areas. If yours has a light, the light should turn off and on as you open and close the door.
SOURCE: wont power on
The blinking red light means that the projection bulb ($150+/- online) needs to be replaced. The access door is located lower right side and replacing is staight forward. Sony has a problem with the Grand Wega that it is denying resposablity for. Check it out by Googling "MSNBC problems with Sony Grand Wega". I would like to get a class action suit going.
SOURCE: GBC Eagle 35 Laminator heats up, won't turn
if you cannot get this fixed....i will buy it for spare parts.....408-802-3843
regards Cliff
