Which point's on satchwell thermostat are live and neutral
2 Suggested Answers
  • 49190 Answers
SOURCE: Positive and neutral on satchwell geyser thermostat
with only 2 terminals it will not matter which wire goes on the terminals
a thermostst is just a spring loaded switch that is adjusted by the knob
the points of the switch are pushed apart by the thermostat medium and the pressure need is set by the spring from the knob
so it is power in -power out= no matter which wire is connected to which terminal
Posted on May 13, 2017
Purchased a flomasta 7593G thermostat to replace my Satchwell TLX2259. I dont understand the wiring? THE satchwell has 3 wires :: 1 = N , 3 = L and 4 = ~ . Which one goes into the flomasta 1,2 ,N,N ?
Im not sure what brand you need i tried looking it up. But here is the website i use for most of my manuals MANUALSBRAIN.COM all you have to do is type what you are looking for. I hope this helps you.
Jan 08, 2018 | Heating & Cooling
Whats the difference between a Satchwell thermostat VK II AND VKF II
Check it out on satchwell controls . Some are fake
Sep 26, 2017 | Heating & Cooling
May 13, 2017 | GPS
Wiring diagram of a Satchwell type70th thermostat switch
need wiring diagram for defy gemini petit chef oven switch
Dec 07, 2010 | Ovens
Satchwell cylinderstat has brown, blue and earth (green/yellow) wires. which is te common and which is connected to the orange on a Honeywell V4073A 3 port valve. I presume the green yellow goes to the...
The colour codes are as follows:
Brown = Line / Active
Blue = Return / Neutral
Green/Yellow = Earth / Ground
It is likely that the Brown and Orange would be connected together but not 100% sure.
Sep 21, 2010 | Plumbing
Central heating - room thermostat Honeywell T6360B
hI he has wired the pump to permanant live there should be link between two of them ? cannot recall which . not much help sorry
Feb 28, 2010 | Honeywell Programmable Thermostat Heater
Wiring connections for a Danfos 25T65 thermostat
3 - Live
4 - Neutral
6 - Earth
With the knob pointing up. Earth it the top right. Live is bottom Right and Neutral if left.
Sep 02, 2009 | Refrigerators
How do i wire a potterton programable controller
All you need to do is look at the wiring diagram on the back of the old room stat, you will have the following:
(normally wired with these colours)
OLD COLOUR CODING
Live (sometimes called common) - Red
Neutral - Blue
Switch Live - Yellow
NEW COLOUR CODING
Live - Brown
Neutral - Grey
Switch Live - Black
All you need to do is wire up the new stat with this in mind. (please note: if the wires are not colour coded like this then do not proceed and get an electrician)
Any problems or questions let me know
I hope this helps
Steve
Apr 23, 2009 | Honeywell Programmable Thermostat Heater
Installing CM900 Honeywell into Junior 24 Bosch Combi
What kind of boiler are using is this boiler a on the demand electric or gas? You need low voltage wires. If you get me make and model # of off boiler i can try and find wiring diagram . Tell me a little more about you heat system to. Like baseboard heat or in floor how many zones
Jan 16, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
