Question about Sanyo Televison & Video
Hello, I need the group code for the remote control. TV Sanyo LCD32XR10F. Appreciate any help so I can programme a generic Remote. Thanks
    Top Expert:
  • Sanyo Master
  • 74,459 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Posted on May 13, 2017
techman
  • 3130 Answers
SOURCE: can't programm TV MW20F11 tOSHIBA COMBINATION WITH ONELINK REMOTE CONTROL
An original type remote is available from 1-800- remotes or http://remotes.com for 27 bucks and change + shipping. I tryed to contact someone about the onelink and they are no longer around as I was told so this is your best bet. Good Luck
Posted on Jun 06, 2006
techman
  • 3130 Answers
SOURCE: generic remote control
Remote transmitters have to have the program in it for the device you are trying to use it with, and the codes simply retreive the progrom, so there are no codes to install as it simply cannot be done. An original replacement can be gotten here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&m1=HT-DB600&uid=11758875673120, or the original remote from Samsung is less expensive and can be gotten here: http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=AH59%2D01169L&search%5Fmodel=HTDB600 Good Luck
Posted on Apr 06, 2007
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
Posted on Feb 10, 2008
VOTIT
  • 2071 Answers
SOURCE: Masterplug tvrc4n 4 in 1 remote control/sanyo
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 23, 2008
SOURCE: Remote control code needed
i have a connect- it bd512 universal remote control i need a code to programme in to my tv it is a baier please help!!!!!!!!!!
Posted on Mar 03, 2009
How do i program my onn remote for my flat screen Sanyo tv
If your ONN remote is programmable, you can search for a code to control your Sanyo TV. If a thorough search through all codes in the remote is unsuccessful, you may have to try another programmable remote.
Dec 06, 2014 | Sanyo Televison & Video
How do i program a sanyo fxrf remote control to my sanyo flat screen
You don't program that remote. It isn't programmable. It's a replacement remote for a specific range of Sanyo TVs: The FX- and GX-series Sanyo TVs.
If your Sanyo TV is not an FX- or GX-series set, then you bought the wrong remote.
Sep 08, 2014 | Televison & Video
I have a jumbo universal remote and i need the code to connect it to my sanyo t.v...how can i get it
Hello
Setup codes for Sanyo TV with Innovage Jumbo remote control are:
004/013/049/108
OK.
Aug 26, 2011 | Innovage Jumbo Remote Control
Chunghop universal tv remote control,what is the code for sanyo tv...
Hello
Setup codes for Sanyo TV with Chunghop RM-962 remote control are:
0013/0031/0044/0074/0119/0120/0121/0122/0123/0162/0167/0170/0182/0195/0205/0711/0730
If you are in need for a three digit code, just cut the first "Zero" form each code and enter. OK
Aug 03, 2011 | Universal Remote Control Remote Control
I just dug up my Phillips Unversal Remote Control for TV, VCR,DVD, etc, however I no longer have its owners manual to dial up the code needed to operate my Sanyo TV. Will you please provide the 4 digit...
Please go to below website you can get the codes to programme your remote.
http://www.urc.philips.com/
Please select the below informations.
1. Location
2. Select your remote
3. On your left side you will have an option called as REMOTE CONTROL CODE FINDER.ff32c84.jpg
4. Select the device you need to programme and the make of the device you will get the codes for your device.
Thank you
Jul 28, 2010 | Philips Televison & Video
Programme a livewire total tv remote
yes go into kitchen open bin drop in these remotes are not meant for our tv/dvd/sat etc they are for a chinese system save your hair chuck it away sorry to say I got one of these oh dear !!!!!!!!
Mar 20, 2010 | Televison & Video
Remote codes for a jvc tv. allforone remote model urc3021b00
I have a samsung dvd and i dont know what code and how to programme it so I can operate my dvd.
Sep 14, 2008 | One For All URC-3021 Remote Control
Need codes please for Jensen JER 422 for Magnabox TV
magnavox tv jer 422 codes are: 1000 1004 1006 1008 1019 1062 1068 1069 1075 1076 1133 1219
Jan 12, 2008 | Jensen JER-422 Universal Remote Control
Televison & Video Logo
29 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
