Question about The Audio Players & Recorders
The volume control of CTK 5000 is disable. The signal is just enough to the left speaker but the right speaker is silence, the volume knob doesn't work it can't adjustly turn down or turn up.
    Problem Solver:
  • 30 Answers
Reset the settings...
Posted on May 13, 2017
Volume not responsive to knob
If there is any sound from speakers, but don't change volume by knob, and after power switching off and on don"t solve the problem (if there is a batery power in keyboard, take out these!) - there is a hardware (electronic) problem; repairable only in serviss.
Dec 18, 2013 | Casio CTK 4000
Balance control
The channel that is weak will either have a faulty transistor or a bad capacitor on it. Most engineers would test it by injecting signals into the circuit at different points. Working backwards from the front end. When the signal goes weak, you have found the faulty stage.
Jul 02, 2017 | Yamaha RX-V690 Receiver
Can i connect juster speakers 675 to my dell laptop?
Plug the power transformer into the bottom jack on the back of the right-channel speaker. This is the speaker with the on/off knob on the front. 2 Plug the audio cable attached to the left-channel speaker into the audio jack on the back of the right-channel speaker. The jack is immediately above the jack for the power cord. 3 Plug the audio jack attached to the back of the right-channel speaker into the headphone jack on a laptop computer (usually located along the left edge), or to the audio output jack on the back of a desktop PC. 4 Plug the speaker transformer into a surge protector and the surge protector into a wall outlet. 5 Turn the on-off and volume control knob clockwise on the front of the right-channel Inspiron speaker to activate the stereo speakers and adjust the volume.
Aug 07, 2012 | Juster : SP-801 Twintower Speakers...
Hi, I have a SR92 which intermittantly cuts out on the right side only. If I quickly flick the volume knob up past about a third the speaker kicks back to life. Doesn't seem to be a pattern to it and I...
Is it on all audio sources or only certain ones? Have you swapped the speakers Left-to-Right to isolate the speaker from the signal chain as a cause?
If it's only an analog source doing it I would suspect a bad audio cable or a switch contact somewhere in the signal path. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute. It's wise to occasionally (with power OFF) manipulate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Mar 15, 2011 | Marantz SR-92 Mark II Receiver
No music coming from my left front speaker. I ran the level calibration and I can hear the pink noise coming loud and clear to that speaker. I have both front speakers set to the same level, but I only...
Looks like your volume control switch is not working on the left side, you can check it by tapping the knob on the volume control and sound will come out on left side.
The only way to get the sound again is to replace the volume control or pull out the volume control and open it up to clean the contacts in it.
Hope that helps you out!
Thanks for using Fixya!
Dec 12, 2010 | Onkyo TX-DS787 Receiver
I have a Jensen DVD media pro 5000 hooked up to a ViewSonic TV in my Camper Trailer. Camper Trailer was purchased with DVD Player and TV in it. At night, due to child sleeping, I would like to be able to...
hi yes you can do this press AUD button near the on/off/volume control momentarily to step through the following audio adjustment options volume, bass,treble, balance (left to right) and fader (front to back). when the desired option appears in the display, rotate the volume control knob to adjust that audio feature. When no adjustments have been made for three seconds, the unit will resume normal operation. so you can fade the speakers to however you want them...hope this helps
Aug 03, 2010 | Audio Players & Recorders
Image is off center bottom is cut off so I cannot see commands
This page is for ACER products. Select the DISPLAY, the choose the correct model for your monitor. There select Guides and Manuals. When you get the PDF file open, look for ADJUSTING DISPLAY SETTINGS. (page 6)
This is what was one one product's manual. This is similar to what my HP monitor uses. Hope this helps.
User Controls
A brief description and the location of all LCD Monitor function controls and indicators:
Figure 2-1
Stereo Speakers
PC Audio Stereo output.
Speaker Volume Control
Increase Volume - Turn the knob clock wise.
Decrease Volume - Turn the knob counter clock wise.
DC Power Switch
Press the power switch to switch the monitor ON/OFF.
DC Power-On Indicator
LED lights Green color --- Power is ON.
LED lights Yellow --- Monitor is in "Power Saving Mode".
LED is off --- Power is OFF.
5
Function Select Buttons
Press either left or right control button for OSD (On Screen Display) menu selection.
6
Adjustment Control Buttons
Press the left button to decrease the OSD setting and press the right button to increase the OSD setting.
7
External Headphone Jack
The monitor speakers will be disabled when using an external headphone or external speakers.
Good luck
Feb 18, 2010 | Acer Computers & Internet
Only one computer speaker recieving a signal
Most probably there is a problem in the cable or plug.
Feb 06, 2009 | Boston Acoustics BA735 Computer Speakers
Top The Audio Players & Recorders Experts
ctlimey
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
