Question about Music
I need circuit board of CTK 5000 - Music
LOOKING FOR A MANUAL
Most Casio keyboard manuals are available from their support page: http://support.casio.com/en/manual/manual.php?cid=008&MODULE= . Here you will need to accept the Casio terms of use. Then scroll down to the correct model. The direct link to the User's Guide is currently http://support.casio.com/en/manual/008/CTK4000_5000_EN.pdf . Casio also has an appendix and documentation on the MIDI standard on the Manuals page for the CTK-5000.
I hope this helps.
Mar 09, 2016 | Casio Ctk-5000 Electronic Keyboard Piano...
Ctk 5000 driver
I prefer, only in CASIO authorized service
Jun 29, 2013 | Casio Ctk-5000 Electronic Keyboard Piano...
Not conect to computer with usb ctk 5000?
Unplug the USB cable.
Download correct driverfor your OS from
http://support.casio.com/en/support/download.php?cid=008&pid=20
You need to load the driver first and only plug in the USB cable when the software tells you to do so.
Aug 28, 2012 | Casio Ctk-5000 Electronic Keyboard Piano...
Casio ctk-501 the power input cracked on the curcit board i did a bypass wiring over the crack and it got power works again but only till i start playing a bunch of keys then the sound gets stuck and the...
When wiring around circuit board cracks, one must use adequate sized wires and keep the leads short. Also you MAY have a microscopic crack in yet another conductor that flexes when you play the keyboard and freezes it. Use a high intensity LED light from the topside to "candle" the board and look for cracks. Look for cracking of the board material that may have tiny cracks in the circuit traces.
Nov 17, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
It got peed by my cat now 5 keys does not work what to do pls help
Sadly, when the circut get damaged by a fluid, it typically has to be taken to a local professional so that they can pull the board out and run tests on it. This is a very intensive process because each componant within the questionable area of the circuit needs to be tested for weaknesses or damage. Most of the time you will pay more for labor than parts, if you want the unit repaired.
I recommend getting a quote and keep your mind open to replacing this unit due to the repair versus replacement.
Aug 29, 2011 | Casio Ctk-5000 Electronic Keyboard Piano...
Busted motherboard
The board is cracked? "busted"... replacement only solution. If non-operational repair the unit. Failure to connect via USB is COMMON and is not indicative of "busted" motherboard.
Jul 11, 2011 | Casio Ctk-5000 Electronic Keyboard Piano...
I have casio CTK 5000. i want to download additional tones and rhythms on it . kindly suggest the site as well as the file formats it will recognize for this model. also kindly describe the total procedure...
It is possible to load new rhythms and tones in the CTK-5000. But you need the stuff. That is what it really lacks. Casio needs the Rhythms and tones in its own formats.
May 15, 2011 | Casio CTK5000 (61Key Portable Keyboard)
I can't get d usb connection and i think the driver is corrupted
Make sure the driver is compatible with your operating system... often stuff will not work with Vista for example. Often SOME software REQUIRES it to be installed before USB cable is connected, and yet other requires it not be connected till software is installed... read the manual...
Jan 21, 2011 | Casio Ctk-5000 Electronic Keyboard Piano...
My Casio CTK-496 Keyboard has three keys (2nd octave F sharp, G, and G sharp that don't play anymore. How do I fix this?
First make sure a keyboard "split" option is not set.
Probably you are going to have to clean the key contacts. They are likely conductive rubber "pills" that are pressed onto a circuit board that has interleaved fingers. Clean both the black pills and the circuit board using ONLY 99% isoprophyl alcohol and Q-Tips.
Feb 17, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
No power is coming through to my CTK 611, bought a new power unit and this has made no difference
There is a chance that the jack that the power supply plugs into is broken loose or has bad solder joints to the circuit board. I am hoping that you purchased a direct replacement for the power supply.
Oct 29, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Music Logo
18 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
