Live and neutral points on satchwell geyser thermostat
Which is the live and the neutral point's on a satchwell vfk geyser thermostat?
2 Suggested Answers
  • 42561 Answers
SOURCE: Positive and neutral on satchwell geyser thermostat
with only 2 terminals it will not matter which wire goes on the terminals
a thermostst is just a spring loaded switch that is adjusted by the knob
the points of the switch are pushed apart by the thermostat medium and the pressure need is set by the spring from the knob
so it is power in -power out= no matter which wire is connected to which terminal
Posted on May 13, 2017
May 13, 2017 | GPS
Where do i connect the geyser load wire to a dhc15a-20a timer
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#PB1
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#FM1
The other terminals are NO NC and Com
Neutral does not connect to these... only Hot
Hot connects to Com... and then connect wire to geyser to the NO contact... general illustration on link above
Sep 19, 2014 | Hardware & Accessories
Triton shower t90si will not cool the water. water is absolutly scalding
hello :>
have a look at ur geyser and what tempreture the thermostat is set on. dont set it lower then 55 degrees or swams will grow in geyser and not higher then 65 degrees or the water will be scolding to qwite hot. plz rate, and let me know if u need more help. thermostat is located on geyser at power point. take off outside shell. put off power when worinking it hehe .U will see a devise with a pin conected with wiers that says most comenly 0-80 degrees. hope that solves it . let me know
Jul 01, 2010 | Home
Central heating - room thermostat Honeywell T6360B
hI he has wired the pump to permanant live there should be link between two of them ? cannot recall which . not much help sorry
Feb 28, 2010 | Honeywell Programmable Thermostat Heater
Wiring connections for a Danfos 25T65 thermostat
3 - Live
4 - Neutral
6 - Earth
With the knob pointing up. Earth it the top right. Live is bottom Right and Neutral if left.
Sep 02, 2009 | Refrigerators
Installing CM900 Honeywell into Junior 24 Bosch Combi
What kind of boiler are using is this boiler a on the demand electric or gas? You need low voltage wires. If you get me make and model # of off boiler i can try and find wiring diagram . Tell me a little more about you heat system to. Like baseboard heat or in floor how many zones
Jan 16, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
