Question about Watches
How to set time,day,date in ajanta odc 130 - Watches
2 Suggested Answers
AndrexT
  • 16272 Answers
SOURCE: HOW TO STOP ALARM SYSTEM IN AJANTA QWARTZ ODC 120 MODEL WATCH
Ask the maker via the Contact page. Looks cheap and nasty!
http://ajantaworld.com/index.php/products/time-products/picture-clock/digital/lcd.html
Posted on Sep 28, 2015
Tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 | Watches
Tip
on Jul 09, 2010 | Watches
HOW TO STOP ALARM SYSTEM IN AJANTA QWARTZ ODC 120 MODEL WATCH. ALARM KEEPS BEEPING EVERY DAY AND I DONT WANT THAT.
Sep 28, 2015 | Watches
How to adjust the correct time of ajanta quartz ODC-120
move the plastic button at the back slightly to the right side where it says "Time" and than adjust the time by pressing 'Mode' and 'Up/Countdown' buttons
Oct 14, 2013 | Watches
I own a Ajanta Quartz odc 170 wall clock but have misplaced the operating instructions. Can someone please help me with the setting instructions. Many thanks. Joshua
There is a sliding button on the back side to the right of inner frame. The slider has "Normal -> Time -> AL SNZ -> CountDown->Timer" marked on it.
You need to move that button to time basically to the right side and then user up and down buttons to adjust the time.
Hope this helps.
-- Anant
Jan 29, 2013 | Watches
I just got a Invicta Corduba watch and I need to set the time. How do I do that? The number on the back is #6675. Thanks
this watch has a screw down crown. lift up the protector bar or start to unscrew down until it pops out, then turn slowly and pul gently all way out. set the time . tere is 2 positions there. full out time and inbetwwen them is the date and day settings.when there turn up or down until date chages, if it has day and date , up is day down is date.you have to turn few times for it to move..set the date ,set day before and go around . the 12 see number change to might date, set the correct time am or pm. push the crown in and screw in up til hand tight.
Jun 17, 2011 | Invicta Watches
I have an eco drive and recently in trying to set the clock back to regular time, I must have done something wrong. The time is correct but the date, and day are one day forward. How do I correct this?
the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
example: you want to change it to sat 12th 11am
set the day and date to fri 11th
then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
Dec 13, 2010 | Citizen Eco-Drive watch
Adjusting day/date on a self winding Seiko, 7S2GB
mcdevito75 here, Your stem has 1 positions to set the date easily without haveing to cycle the watch 60 times. First pull the stem out to set the day, set the day 1 day before the day you want, next, push the crown back in, NOW! Slip a finger nail just under the crown from the back as there is more room, it may take some practice so be patiernt and gently, gently lift the crown to it"s first position, once in it"s first position turn the stem and see the DATE change, set the DATE to 1 DATE before the DATE you want, NOW pull the stem out to set the day date and time of day. Your watch is set and the day date will change on time, a little past mid nite.
Apr 14, 2009 | Seiko SGF204 Wrist Watch
Setting my day date on watch
mcdevito75 here, The stem has 2 positions, first, set the day to 1 day before the day you need, now, slip a finger nail just under the stem and gently, gently lift the crown to it;s first position, set the DATe to 1 date before the date you need. Push crown back in, now pull crown out to set the date and time of day. Your watch is set and should change around mid nite
May 03, 2008 | Seiko SLL003 Wrist Watch
Watches Logo
284 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
