Question about Samsung Televison & Video
Samsung UA48J6300 48"FHD CURVED LED CRACKED THE SCREEN IN INSIDE I BUY THIS TV DECEMBER TIME ON THE 12.12.2016 AT OK FUNITURE SHOP AT ERMELO I NEED HELP PLS
SOURCE: LCD + Screen Broken, Help Needed!
Ive found a service manual here http://www.scribd.com/doc/209795/Samsung-SGHU600-service-manual
however seems a bit dodge as he takes off the IMEI label and stuff and al i wanna do is change the screen!
Posted on Feb 27, 2008
  • 395 Answers
SOURCE: need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Posted on Mar 11, 2008
SOURCE: Samsung YP-P2 cracked screen
hi! i had a cracked screen too the only way i could repair it is to send to samsung they repair it free! if it broke on physical use then they will charge u.
Posted on Jun 07, 2008
SOURCE: tv repair
My aquos plat screen tv was pushed over by my three year old. The screen is damaged but everything esle works. Is this problem fixable?
thank you
Posted on Nov 24, 2008
  • 59 Answers
SOURCE: Cracked LCD Screen
check ebay online for parts. the problem with a cracked screen is that to get it new, it cost too much. sometimes i find tv's that don't work but have good screens on ebay and you can pick them up cheap. good luck.
david
Posted on May 25, 2009
My Samsung 22" led smart tv has things that look like ink dots and white lines I think It is cracked is it fixable, meaning I can buy a new part or am I going to have to surprise my mom and be like...
The screen is the most expensive part of the TV. You have to remove every part inside the TV to get to the screws holding the screen into the bezel. That cost will be enormous Time to fess up to your mom and say "supersize....we need a new TV".
Jul 28, 2017 | Samsung Televison & Video
Samsung Curved Tv screen went black, how much will it cost to fix?
If set is less than a year old it is covered by warranty. Otherwise it is gonna cost more than what you want to pay for a relatively new set!
Feb 04, 2016 | Samsung UN55HU8700 - 55-inch Curved 4K...
I have a 55 led flat screen samsung, that has color lines on one side of the TV slightly during the picture , whats the problem
The same thing happened to a relative of mine. They still have the tv but it only occurred when they dropped it. The screens layers inside must have cracked. It could have also happened from pressure being put against the screen in the area of the colors. They asked the shop they bought it in & was told it can't be fixed and they would need a new one. Hope this helps.
Jul 11, 2015 | Televison & Video
I have a cracked samsung un55eh6050 led tv. Is it under any warranty? It one and a half years old.
Ralph
if you do not find your warranty card for the tv. Phone the shop that sold you the tv and ask them. Have the registration number handy when you talk to them.
you will probably be able to find that in the menu under Settings- general- about,
best of luck
kolbrun
Mar 25, 2014 | Samsung Televison & Video
Samsung led tv ua40F6400 power board
If you wish to buy a new power board, contact the authorized service centre for Samsung.
Jun 27, 2013 | Televison & Video
Screen cracked
Unfortunately the only option with a cracked screen is to buy a new tv. These screens are more expensive to replace than to buy a new tv. The only other option you may have is to sell the tv with the cracked screen to someone for parts who has the same model tv or maybe a tv repair shop will buy it from you. With that being said, you might can call some repair shops and who knows, maybe they have a screen from a disposed tv that will work. Whatever the case you are better off just buying a new tv and either keeping that one or selling it for parts.
Mar 08, 2010 | Samsung LN-T4671F 46 in. LCD Television
Televison & Video Logo
Henry  Thomas
Henry Thomas
