Question about Garden
I have a mountfield 727h ride on and I need to top up the oil, what oil should I put in?
Why wont my mountfield 725m mower go into blade motion
I would check the mower deck itself. This usually happens when it clogs with grass or something got jammed in the belt or pulleys.
Aug 30, 2014 | Garden
Mountfield RY150 the self propelling arm missing
You can try http://www.jungle-busters.co.uk/Lawn-Mower-Spares/Mountfield-GGP-Spare-Parts
I have gotten hard to find parts from them in the past and they do carry stuff for the mountfield machines
Dec 05, 2013 | Garden
SP740 mountfield mower is not doing anything when i push the primer button. i used to hear and feel liquid but its empty just hear air. i have oil and petrol in it, what am i doing wrong
there is a contraption in electronics called a diode. it is a one way street, current can only flow one way. well in the socket behind the primer bulb is a flap which does the same thing with fluids. either the flap or the bulb as become corrupted, or the small passage the fuel is drawn through has become plugged. you need to get a rebuild kit, take the carb apart, thoroughly clean it, and then put it back together with the parts from the rebuild kit
Sep 23, 2011 | Garden
How do you change the oil in a mountfield LS45 Lawnmower???
While I am not familiar with this brand, typically, in a four cycle lawn mower engine, there will be a oil drain plug in the bottom of the engine or on the lower part of the engine above the deck.
Thanks for your question @ FixYa.com
May 19, 2011 | Garden
I require parts No for OPC/Clutch cable Holder/bracket for Mountfield Mower Model SP480T
Please see www.jungle-busters.co.uk/Mountfield-Cable-Holder for also very handy for any other mountfield mower spares
Oct 01, 2010 | Garden
After the machine has been running for about 45
Have you checked the oil? many motors have an oil pressure switch. When did you last change it? if the oil gets hot and thin, there is less oil pressure. Could also be a safety switch, vibrating loose. Switch on seat maybe?
Jul 12, 2010 | Garden
Mountfield mower manual
it seems this mower is made by Homelite with the Mountfield name on it.
May have to see if you can locate a source for homelite to find this manual.
cheers
Sep 26, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
