Question about The Office Equipment & Supplies
Is the fax vx33 and the vstduet1600 the same machine? Which one is the newest model?
Sony mini hi-fi system MHCVX33 Audio-VCD, i want to change (Track CD to DVD Mp3 format)
Not possible. DVD to MP3 is a transitional change using a software program like that from Wondershare.
Feb 02, 2015 | Sony Audio Players & Recorders
Sony mini hi-fi system MHC-VX33 Audio-VCD to DVD
Sony mini hi-fi system MHC-VX33 Audio-VCD to DVD is doing what?
Change baud rate on brother fax machine
Lowering the Baud rate on Brother fax machines.
  • Press the Menu or Menu/Set key. Then Fax, Miscellaneous and Compatibility.
  • Press the Up or Down key until you can select Basic. Basic reduces the modem speed to 9600 bps.
  • Press OK or Menu/Set or Set key.
  • Press Stop/Exit.
Note these instructions should work for the following models: Fax-1835C, Fax-1840C, Fax-1940CN, Fax-2440C, Fax-2820, Fax-2825, Fax-2920, MFC-210C, MFC-215C, MFC-240C, MFC-3240C, MFC-3340c, and most other MFC models.
Mar 06, 2012 | Brother FAX-8360P Plain Paper Laser
I want samsung smarthru scanner drivers model no:scx-4521f
go to samsung web page and write your printer model in the little window then download the newest drivers from the download page, you will need 1. driver for the printer, 2. driver for the scanner, 3. driver for the fax and last samsung Dr. Printer
Apr 17, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Cannot receive faxes
What is the make and model?
Call the fax machine from a regular phone to see if it answers.
I think you have some sort of phone line problem.
Fax machine modems are good or bad, nothing in-between.
Mar 13, 2009 | Office Equipment & Supplies
Uf 7000 panasonic fax machine
try doing an all job clear on the machine and getting a dealer to update the firmware to the newest one.
Jul 07, 2008 | Panasonic Office Equipment & Supplies
Fax picking up over phone number
Do you have an Answering Machine?
If yes then the Rings to answer on the Fax should be more than the rings to answer on the Answering machine.
Press the Setup button on the Printer and then go to Basic Fax setup and you will get the Rings to Answer option there.
May 25, 2008 | HP Officejet 5610 All-In-One InkJet...
Fax error
I have the same issue onthe same model! wtf?
Apr 22, 2008 | Office Equipment & Supplies
ok...try a test page first, with printer off the computer completely
and..check for newest printer drivers here
Mar 04, 2008 | HP PSC 2210 All-In-One InkJet Printer
Defective sony vcd Model MHC-VX33
If it havent been use for a long time try dusting it and cleaning it first, sometimes dirt gets stuck on vital places which makes it go crazy. Hope this works. Please dont forget your rating for me as well...We take time in answering problems. Thanks
Jan 25, 2008 | Audio Players & Recorders
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
