Question about Canon imageRUNNER 105 Copier
Canon Image Runner iR3300 Printer Tray selection problem in Linux
My Canon iR3300 is installed with Fedora. When I print the test page the printer tray is selected as per the printer default setting. But, When I print the pages from Open Office writer or any other editor, the printer is asking to select the tray manually. I have selected almost all of the options provided. Tried updating new Cups, different printer drivers available over the web, etc., but no resolution. The system is working with Windows properly. In ubuntu, RedHat, Fedora Linux versions the same problem is replicated. please help me to resolve this problem.
  • ironleg Nov 20, 2009
    SIR
    MY OS IS UBANTU 8.04
    I HAVE CANON iR3300 PRINTER
    PRINTING IS GOOD
    BUT SCANNIG
    HOW TO USE SCANNER IN UBANTU
    I KEPT IN SCANNER MODE BUT THERE IS NO USE
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 89 Answers
This is an old copier. My guess is that unless a new driver comes out to fix it that there isn't too much hope of the problem going away.
You could load latest firmware onto the copier if it doesn't have the latest but it's doubtful whether that would help.
Posted on Aug 18, 2009
When i am sending print commands iam getting contiues printouts and the images is not printing completely
Posted on Jan 14, 2010
In canon IR3300 paper doesnot recognize at all and says load paper every time
on ur PC right click on your image runner go to printer proprieties go to preferences go to default paper size and choose your required size.
Mar 22, 2016 | Canon imageRUNNER 3300 All-In-One Laser...
How do I make a copy using the bypass tray with card stock on the canon image runner 1310?
You have to select the paper tray(in this case bypass)when you make a copy.
Dec 10, 2014 | Canon imageRUNNER 1310 Printer
HP Photosmart Printer 7850 I would like to print a self-test page because I want to know if the problems are with the printer or the applications I cannot install any windows software because there is only...
Here's how to print a self-test page.
HP Photosmart 7850 series printers
  1. Make sure plain paper is loaded in the In Tray and the printer is on.
  2. Press and hold the Select button.
  3. Press the Left arrow button once.
  4. Release the Select button.
Jan 04, 2011 | HP Photosmart 7850 InkJet Printer
Canon Image Runner 7200 prints twice instead of once. When I ask for two copies I get four copies.
If you are using Windows, you will want to check the drivers of the printer to make sure you are not selected on 2 copies.
Go to Control Panel\Printers and faxes
Right click on the printer driver and select "printing preferences".
Make sure the "Copies" is set to 1.
You can also try a wtest page by going to "properties" and select "print test page".
Mar 25, 2010 | Canon imageRUNNER 7200 Copier
Printer is ''stuck'' on a bad job
Go to computer, control panel, printers, Under you Image runner right click and cancel all print jobs.
Nov 14, 2009 | Canon imageRUNNER 5000 Copier
When i am going for scan my machine display this massge this function requires optional equipment
Image Runner 3300 or (iR3300) copiers do not come with print/scan OPTIONS installed. These functions must be enabled by installing the correct 'kit'....same with fax option...again, these were 'options' when this machine was introduced, no print, scan, fax,...unless options were added to it. Yes, the buttons are there, however.....
Nov 10, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
We just received some used Canon Image runner 1310 copier/printer and I not have it hooked up to my computer. It is printing just a little off....it slants to one side. Any idea's why?
hi, wel now that you have two questions i still working on your first :P
this copier may only take paper from two diferent trays.
one is named the multi-purpose tray an dthe other just the cassette.
so i gathered you want to print using the MP tray, right? to copy from the bypass (or MP) tray, just choose it using the paper select button (take a look at the panel, there's a button that actually says 'paper select') . now if you want to print from it, go to your printer settings and change the default paper source to the mp tray.
about the other problem im still trying to figure out your problem.
Jan 28, 2009 | Canon imageRUNNER 1310 Printer
Info
Canon ir3300 is a black and white 33 ppm (A4) copier , printer (network), fax and scanner ( b/w).
For more info please visit canon website.
Sep 26, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon imageRUNNER 105 Copier Logo
656 people viewed this question
old marine
old marine
