Question about Refrigerators
Inter grated fridge freezer model number BC50F, the fan in the freezer is working intermittent
zeusfaber
  • 247 Answers
SOURCE: Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
Posted on Feb 28, 2008
22yooper
  • 828 Answers
SOURCE: Fridge Fan noisey, Fridge temperature
Fan motor bearings bad if it is a high pitched noise. If the fan is not running up to its full speed it will affect the refrigerator temperature.
Posted on May 27, 2008
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
SOURCE: SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Posted on Oct 13, 2009
SOURCE: fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
Fan not working, fridge not cooling anymore, freezer seems ok
Hotpoint Fridge Freezer RFA52 BUT I DONT KNOW WHERE IS THE FAN CAN SOMEONE HELP ME TO TELL ME WHERE IS THE FAN IN MY FRIDGE SO I CAN DEFROSE IT.
PLESAE EMAIL ME ON: RAFIK02UK@YAHOO.CO.UK
MANY THANKS
Posted on Mar 01, 2010
Fridges stops working randomly but the freezer works. Then the fridge starts working after a couple of days
When the fridge stops working, can you hear the fan operating inside the unit? It sounds like you have a failing evaporator fan motor. This fan motor circulated cold air from the freezer to the refrigerator.
Apr 19, 2015 | Refrigerators
Hi my Beco bc50f fridge is freezing goods despite being on the minimum setting . I was going to buy and fit a new thermostat but a blog suggests that it could be something else, the fan in the freezer...
There is a vent that controls the cold air flow into the refrigerator section from the freezer.
The thermostat controls the vent but the vent may be broken or stuck open.
Probable thermostat, but the vent is likely, too. You will need to open it up and inspect the parts.
Mar 02, 2015 | Refrigerators
I have a dometic rv fridge, the freezer works not the fridge
you have to send the brand name and model number so i can help you.all that happens is the evapcoil in the freezer gets cold,the evap fan motor blows cold air from the freezer into the fridge side,depending on your model you could have a bad damper,this is a door that is in the fridge section,it opens and closes letting the air come in,try this,open the freezer door,if you don't hear the fan blowing you could have a bad fan motor,also touch your hand on the back inside wall of the freezer,if you have frost or like ice on the back wall you have a defrost problem,ice is biulding up on the coil and the fan can't blow the air over to the other side..if you need more help,do these tests and send the model number off of the machine and brand name,side by side or freezer on bottom,open the fridge door,look up on right hand side wall near ceiling or on ceiling,freezer on top look on left side in fridge section.
Jul 12, 2012 | Dometic Refrigerators
The blower in frig is not working, frig is warm freezer is working fine, we have vacuumed all area & unplugged for serveral hours. please tell us what else we can try.
all it does is blow cold air from the freezer into the fridge section,open the freezer door,you should hear the fan blowing,no fan fridge will be warm bad evap fan motor,also send the brand name and model number,some machines have dampers in them if the damper is bad it blocks the cold air from entering the fridge section,send model number and brand name,
Sep 25, 2011 | Refrigerators
The freezer works well but the fridgedoes not get cold enough
all the fridge does is blow cold air from the freezer down into the fridge section so if the freezer is working then either the evap fan isn't working or the air ducts are frozen up.first thing open the freezer door,you should hear the fan blowing,if not the fan motor could be bad,if it is blowing,touch the back inside wall of the freezer,is there any ice or like snow on it,if so you have a defrost problem,one more thing to check,open the fridge door,look under the bottom draws,is there any water there? or any water dripping into the fridge section from the freezer,if so you have a blocked drain and the air ducts are frozen.let me know what you find,send the model number off of the fridge,open the fridge door and look on the left side up near the ceiling,you should see a tag with the model and serial numbers just send the model
Jun 05, 2011 | Kenmore 21.7 cu. ft. Top Mount...
Servis Fridge Freezer not working
fridge appears to be working, but freezers section intermittingly keeps going off
Apr 19, 2010 | Refrigerators
Please can you help me my fridge peezer FFA60 FUTURE fridge freezer isnt working right, my freezer is great but my fridge seems to stop & start altough the light is still on, if I turn off plug it...
that model number does not come up in my program, so I cannot give you any concrete advice. The fact that your freezer is great is a good sign, nothing major. Sounds like you may have a bad freezer fan motor, not blowing cold air down to the fridge section. but the fact that it is intermittent like that, you might have a faulty main control board. Without proper inspection, I cant say for sure.
www.FixMyFridge.net
Mar 08, 2010 | Hotpoint FFA60 Bottom Freezer Refrigerator
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Fan runs freezer and fridge don't cool
Please check the model number again, I can't locate that number. The number should be like for example 194.258978 Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • I think your refrigerator has a defrost timer and this may be the problem, Let me know what you find, Thanks, Sea Breeze
Mar 29, 2009 | Kenmore Refrigerators
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
