Question about Samsung Televison & Video
Samsung un32f5000af backlight
The backlight on my tv has gone out and I am curios on how I should go about fixing it
My Samsung UN32F5000AFXZA Version TS01 lost picture but still has audion
T con board responsible for picture. Just make sure that the back lights are working first. If they are not working after conducting flashlight test then it is the inverter board.
Aug 25, 2017 | Samsung UN32F5000AFXZA - UN32F5000AF 32...
I have a Samsung 32" LED tv model number UN32F5500FXZA. It has sound but no picture but passes the flash light test. I don't see any backlights. Any idea what the part is?
The backlights are located around the edge of screen inside the tv. Now this model is know to have LED failures. The LED strips are you backlights. The LED strips are powered by the power supply board but due to the fact that this model is know to have LED failures, I would recommend replacement of the LED strips, all of them, first. Samsung BN96 25300A Replacement LED Strips UN32F5000AF UN32F6300AF
This website currently doen't have the parts in stock for your tv however this will help you identify the parts and they even have some tutorials.
Feb 04, 2017 | Samsung Televison & Video
How do you fix a Samsung 55" Television with no picture but good sound?
The symptoms you described would indicate the backlights are not working.
The 2 main reasons are the backlight inverter board has gone or the backlights have blown!
Since you have replaced the inverter board with a new working one then this would point towards the LED backlights.
Apr 02, 2016 | Samsung Televison & Video
We bought a chomecast router for this product and cant find a code to connecr it
have had TV's a long time and still do not need a router for one .just a good outdoor antenna .
Nov 05, 2015 | Samsung UN32F5000AF 32 LED 5000 Series TV...
Samsung ln40b550k1f screen flickers on and off
When the screen flickers on and off it usually comes from the power supply or backlight inverter being bad. For your TV, the backlight inverter and power supply unit are combined. As you can see in the picture attached it's the white part on the right side that has gone bad. You will need to replace that board. LN40B550K1F Samsung LCD TV Repair Guide
Mar 11, 2013 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Shadow area on LCD screen.
one or more of the led back light lights has probably gone out and there is no way to fix it except to get a new backlight
Jan 20, 2010 | Emerson EWL3706 37 in. LCD Television
Picture goes off after a few minutes but sound remains. what is the problem?
There are a number reasons why this might happen:
  • The backlight has gone (Find a dark place and shine a torch into the screen and see if you can see an image in the background, if you see an image then the backlight has gone) - Needs a new backlight (Engineer to remove and fit) or have a new panel fitted.
  • The panel has died - Need a new panel
  • A cable has worked itself loose or is broken
  • The inverter has gone - Need new inverter
  • The driver board is faulty
Oct 02, 2009 | Samsung LA40A550 40 in. HD-Ready LCD TV
Picture gone from TV Model LE46M51B
I suspect that your backlight has gone out. If you shine a light on the screen can you see remnants of the picture that should be displaying? If so, it's definitely the backlight, and most likely the power inverter for the backlight. You can probably find a replacement inverter, but you may need a repair manual to install it. I'd recommend checking the warranty status first and sending it in for repair if you can.
Feb 17, 2008 | Televison & Video
Televison & Video Logo
53 people viewed this question
Jerry Greenberg
Jerry Greenberg
