Question about Westinghouse Refrigerators
What temperatures should I set for a Westinghouse WBE5100SB-R
My Westinghouse fridge reads CN AND ER on the control panel temperature settings
Communications error between the control panel and the main electronic controller. Unplug it for about 10 minutes, then plug it back in. If the error comes back, you have some bad components. It will need to be repaired.
Aug 02, 2016 | Westinghouse Refrigerators
I HAVE A WESTINGHOUSE FRIDGE. CAN ANYONE TELL ME THE BEST TEMPERATURE TO SET THE FRIDGE AND FREEZER TO
Probably no best, but they are adjustable to your own preferance. The MFG Owner's manual has a "factory" recommendation.
NO owner's manual? try manualslib.com
May 07, 2015 | Westinghouse Refrigerators
My Westinghouse freezer has an alarm beep that goes off every now and then and the only way to stop it is to turn off the fridge completely. In the fridge section the temperature panel flashes the...
Often these have door alarms. If the door isn't completely sealed shut then it will alarm and cause the temperature/thermostat to blink to warn of "warm" temperature inside the fridge
Mar 04, 2015 | Westinghouse Refrigerators
How do I set the temperature on my WSE6100SF fridge
Westinghouse manuals available for download from
http://www.westinghouse.co.nz/SupportCentre
Just enter your model number WSE6100SF and download the manual.
Sep 05, 2013 | Westinghouse Refrigerators
Westinghouse freezer is not freezing and the temp is getting higher. do I need to replace freon? or is there another issue. everything seems to be working and it is running. it is an older model. ...
Last would be refrigerent unless you were aware of a leak (corroded pipe, ice build up on pipes) or gurgling noise when compress cycle is on.
Check temperature control thermostat is working. As this is electrical you need a repair person. If the temperature control passed the electrical function test, the problem may be a defective temperature sensing bulb on the temperature control. The temperature-sensing bulb is an integral part of the temperature control switch, so you need to replace the complete control.
Sep 04, 2013 | Westinghouse Refrigerators
I have an Westinghouse Silhouette 121 freezer. At bottom rear there is an adjuster for Temperature setting. Can you advise how much I should turn this screw adjuster? It reads "Off" at one...
For best performance set the control at a mid point between OFF and HIGH.
The closer you set it to OFF the warmer the freezer.
The closer to the right HIGH the colder the freezer.
Jun 11, 2011 | Westinghouse Refrigerators
My westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Nov 08, 2009 | Westinghouse Refrigerators
Refrigerators Logo
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
