Question about Whirlpool Refrigerators
My whirlpool won't make ice after changing filter model number wrx7355dbm00 sn k54117351
catriver
  • 878 Answers
SOURCE: Ice maker sotp making ice / red light blinking
J, As you open the freezer door the LED on the right should flash 2X with a pause repeatedly. When you hold the left side emmiter down the light should stay on steady. If you have this, you know the optics are good unless the ejector blades are not home. First thing to check is where the ejector blades on the ice maker are parked. They should be resting in the 2:00 position. If they are not, you could have a broken module. If they are in the 2:00 positon the next thing to check would be the fill tube. You want to make sure it is not frozen over. You can disconnect it from the back and see if you can blow through the line or visually inspect it. If all of the above mentioned check out, jump start the ice-maker. Remove the quarter inch screw holding the harness cover on the right side. Remove the harness cover. Pull the ice-maker straight out but be carefull not to smash the emmitter flap on the left side. Leave the harness connected. Get a jumper wire with the ends stripped apout a 1/4 inch. Unplug the refer and place the jumper in test holes T&H. Leave the jumper in and place the ice maker on the shelf where you can close the door. Close the door and plug the refer back in. Wait 30 seconds and open the door. The ice maker should be cycleing. Pull the jumper and place the module cover back on. Put the ice maker back in the rails. It should fill at approx the 12:00 position. Let me know how you make out. Catriver.
Posted on Jul 08, 2007
tech master
  • 120 Answers
SOURCE: Whirlpool Side by side Ice maker
check water valve for ice maker how old is the ice maker is more than 3 years then it might need replacement as well
Posted on Nov 03, 2008
Sea Breeze
  • 4655 Answers
SOURCE: I have a Whirlpool Refrigerator Model 25SSA made
OK there could be several things to cause that. The dual water control valve is defective. Ice blocking the fill tube leading to the ice maker. Thermostat inside the ice maker. When the ice maker stopped what position was it in? Let me know and I will help you. Sea Breeze
Posted on Jun 21, 2009
aasc
  • 1606 Answers
SOURCE: Ice maker not producing any ice.
Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
Do not replace the filter if water flow is good thru the dispensor .
Posted on Aug 16, 2009
milten1
  • 1304 Answers
SOURCE: How do I change the water filter in the Whirlpool
the water filter is in the toe kick on the bottom
it is a push twist type and should almost pop out when in the right position.
the best buty online right now i know of is at appliancepartspro.com
your looking for part number AP3182816
29.00
tell them you want the dealer discount and order 3
you will use em and you might get an additional
15 percent off no guarentee
have a great day
Posted on Oct 06, 2009
I changed water filter on whirlpool refrigerator & now do not get water or ice. What did I do?
You have to put it properly. Other wise dispenser circuit signal will not pass through the filter compartment. When to install depend on the model. Put your model number at www.whirlpoolparts.ca website and see the diagrams.
Oct 12, 2014 | Whirlpool Refrigerators
Whirlpool refrigerator won't make ice--just out of warranty
I would have to say control board but you could look for a bin level switch. This is what tells the machine that the ice Bin is full. If it is duty or damaged the machine will never make ice as it thinks there is enough already there
Sep 05, 2012 | Whirlpool Refrigerators
Frigidaire side by side won't make ice but water comes from the dispenser
you either have a bad water valve,bad ice maker,also when was the last time you changed the filter?if it has a whirlpool ice maker you can pop off the cover on the ice maker,jump out the ice maker by sticking a jumper wire into the t and h,let it run for 15 to 20 seconds and pull the wire out,the ice maker should keep spinning,if it does go all the way around the water should come in when the white arms are at 11 oclock,if the water doesn't fill into the ice maker you can jump out the water valve from the ice maker,it says to jump it out from v to n but i jump it from v to L,if it fills with water the ice maker is bad,no water the valve is bad.you have a double valve,one for the dispenser and one for the ice maker but if one fails you have to change out the valve and it comes with both.next time send the full model number off of the machine and i can look it up and see what valve and ice maker is on your machine,when you find out what the problem is,call your parts store,give them the model number and they'll sell you the correct part.http://fixitnow.com/wp/2010/09/05/whirlpool-built-modular-icemaker-wiring-diagram-and-test-points/ copy and paste and it will show you how to jump out the ice maker.
Nov 14, 2011 | Refrigerators
I changed the water filter for the first time in my fridge and now my ice maker is not making ice and the water in the door are not working.
pop it out and put it back in,also did you call a parts store,give them the full model number off of the machine to make sure you have the correct filter.if you want send the model number to me and i can look up your filter.did this happen right after you changed the filter or did you change the filter because you thought this was the problem?
Feb 27, 2011 | Whirlpool Refrigerators
Cannot find the filter on the whirlpool ED2CHQXKB05. The ice maker is producing ice with a white film on it. I was told to change the filter only I cannot locate a filter.
From what I can see with your model number you do not have a water filter contained within the cabinet. You can install an inline water filer between the source and the refrigerator. Also, you will likely have hard water stains in the ice maker mold itself, FYI.
Oct 01, 2010 | Refrigerators
Ice maker doesn't make ice anymore. The water works and dispenser levers on the door work for both ice (use store bought ice dumped into tray) and water. I replaced the filter after it quit making ice. Not...
you've already done the first thing i suggest, and that is to change the water filter. But if you still cant get ice made, you have a problem with either your ice maker or your water valve, or an electrical issue in the ice maker system.
Apr 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool indoor ice maker not making ice
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
Sep 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker
filter its on the kick plate @ the bottom of the freezer door,push the side button and the filter unlocks
Jun 17, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Refrigerators Logo
46 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
