Question about HP Boating
I need to cart a100 hp 4 stroke outboard 250 k what side do I lay it down on
  • HP Master
  • 2,189 Answers
The best safest way is to mount it in a frame by its clamps or drain all oil and pad it well doesn't matter which side you use downwards
Posted on May 13, 2017
I have a 6hp 4 stroke outboard that I will be transporting. Which side do I lay it on?
Hi Don
I'm afraid I'll need to know the make of your OB before I can begin to help you out.
FWIW, our Honda 15 is transported with the tiller handle side down.
Mar 08, 2017 | Boating
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Jun 25, 2015 | Mercury Marine 15hp & 20hp 4 Stroke...
Yamaha 4 hp outboard steering friction swivel screw does not work
That's a current problem.
OR the screw is rusted in place. So then use WD40 or eqivalent to free the screw.
Or the parts inside are worn. Remove the friction screw. Then, remove the 4 bolts holding the swivel cap. Remove the entire engine from the swivel to prevent it fall on the ground. Replace the worn parts.
Jan 18, 2014 | Clymer Marine Maintenance and Repair...
How do i set timing on a 1996 mariner 40 hp 4 cylinder 2 stroke outboard?
timing marks on flywheel and a pointer above the carbs , under the flywheel there is an adjustable rod from the trigger to the throttle linkage ! strobe light required , cant remember timing off top of my head as out so google it !
Aug 21, 2013 | Clymer Marine Maintenance and Repair...
Outboard 115 yamaha misfiring at low revs
Unscrew the 4 idle mixture screws 1/2 turn 1 at the time till sneezing stops...
Clean your carburettors
Oct 31, 2012 | Clymer Marine Maintenance and Repair...
About 4 yrs old 90? hp 4 stroke outboard runs
ignition timing may be off slightly.
Mar 12, 2010 | Boating
Boating Logo
Top HP Boating Experts
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a HP Boating Expert? Answer questions, earn points and help others
