Question about Dual Audio Players & Recorders
Where can I get a single cable for a Gemsound CD 70 dual CD with pitch control?
3 Suggested Answers
  • 323 Answers
SOURCE: where to find gemsound cdm-150 instruction manual
http://www.geminidj.com/product_manuals/cd-150_10_10_05.pdf
I believe this is what you are looking for ;)
Posted on Apr 19, 2008
  • 191 Answers
SOURCE: need remote cable from.controler to cd decks
saxophones dont have cables. More details please
Posted on Jun 06, 2014
Copy video dvd-r to blank cd-r
You won't have any luck doing that. First off, CDs [including CD-Rs] can only hold 70 Mb of data. DVDs can contain anywhere from 4.7 Gb to 50 Gb of data. That amount depends on if the DVD is a single layer, dual layer, BlueRay or High Capacity BlueRay disc. Therefore, a CD simply does not have enough storage capacity to hold the info on a DVD.
Feb 16, 2015 | Computers & Internet
How do i hook up the mp3 to the cmp500
Are you asking how to hook up an external Mp3 player to your CMP deck?
Dec 02, 2014 | Gem Sound GemSound CMP500 TableTop Dual...
Why has the heater quit and blows only cold air on passenger side of my dual climate control on Buick Lucerne
Sounds like a a venting problem. Most cars up until now days and some still do use vacum assist to change venting from hot to cold and changing different vent configurations. So you have a vacuum leek somewhere in the system. If they are mechanical then its a fuse most likely . also in older cars there were cable system's witch controlled everything. If you here hissing sounds you know you have a vacuum leek somewhere in the system. If there is a worrying sound something is jammed up mechanical problem. It's a needle in the hay stack sometimes trying to figure out and you have to do it by deduction to figure out what the real problem is. Good luck
Sep 17, 2014 | Metra 70-7864-DZ Dual Climate Controls to...
The right side Pitch slider knob is broken on my GemSound CMP 1200 MIDI. Can it be repaired and what will it cost?
When you say "broken" do you mean the entire slider or just the knob? Because if it's just the knob, you can just take it to an electrical parts shop such as Maplin (UK) or Radio Shack (USA) and find something similar or that matches it. Ask the assistant if for help if you can't find it. If it will fit, but doesn't match, buy two so that you can match them up. They shouldn't be expensive.
If the controller is broken you might have to find a dealer who repairs that brand. As it's not a widely known brand you might have to pay a bit more, being less competition around.
Sep 18, 2013 | Gem Sound GemSound PA-585 2-Channel...
Pitch control doesn't work
Make sure that the "Pitch" button is turned on (LED is lit) before trying to change the pitch. If it is, make sure that it's not disabled in the settings.
May 18, 2012 | Numark CD MIX 1 Integrated Dual CD Player...
What does "multi layer support" mean. Does it write multi layer discs? or is it able only to read them? Also, what is a lightscribe?
Multi-Layer support means the drive can Read/Write a Dual-Layer discs.
Lightscribe means you can create a label on a disk.
Check these Links fro more information:
http://en.wikipedia.org/wiki/LightScribe
http://www.lightscribe.com/gettingstarted/index.aspx
Good Luck!!!!!!!!!!!!!!
Sep 18, 2009 | HP Pavilion dv1000 Notebook
Player 2 skips and plays a different track
May need manual cleaning or Cd Mechanical assembly may need to be replaced
Dec 03, 2008 | Nu Mark Numark Cdn36 Dual CD Player CD...
Gemsound power speaker pxa105
First,
Disconnect any input cables from the amp. Turn down the volume controls and disconnect the speakers. Power back on. If you still blow fuses with nothing hooked up, have the amp fixed.
If the fuse holds, shut down and connect the speakers, leaving the volume controls down. Power up and see if your fuse holds. If you have hum, an output transistor is most likely shorted. If you have no noise, SLOWLY turn up the volume controls and listen for the hum. If all is quiet, turn down the volume controls and connect your input cables and turn the volume back up. Noise? check your cables!
Mister Phil
Apr 07, 2008 | NAD C350 2-Channel Amplifier
41 people viewed this question
Top Dual Audio Players & Recorders Experts
Jerry Naidoo
Michial Gueffroy
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
